What is maintenance history??Last gear oil change, brake service, balancing, alignment, tuning, tires change, wheel bearing change, radiator coolant, brake oil change etc etc ?
@mani001002 may help u.He recently changed his cuore' lamps.Or @meh1 , senior expert here.
Bro no idea abt black smoke. @meh1 may help u.
what is model of your cuore?mostly cause is wiring or joints. better get kabuli wiring for headlights. otherwise change wires. if u change wires, there will be joints.headlight's reflector and lens should be shining clean.another option is to install relays and use 100w bulbs. Make sure electrician uses fuses where wire for relay comes out otherwise its very dangerous.
black smoke means running rich. u should not have accepted it if car was giving smoke. I understand your concern. good mileage plus point of cuore. and its fun to run cuore on petrol while fuel prices are low. it seems engine lacks power and turning ac makes it work hard. mileage on CNG is satisfactory.
Osram and philips headlights bulbs are best i am using from last 2 months I also have stock for sale Philips xtream vision and osram night breaker unlimited both are h4 60/55WFor further details sms or call 03125352060
Philips XtremeVision and Osram Night Breaker both available with me.
@smartdevil_striker pm me your number.
engine dont reduce oil.AC serviced in this season...i did tune car from 2 or 3 locations..but consumption problum is same with AC...so should i go to check out the AC ?
Bro..I have 10 model cuore... electrician advised me to go for a "Cut out". But I don't know what does this term mean. Anyway I went to electrician and replaced the existing bulbs with 100w bulbs. Performance though improved but not up to the mark.. my mehran model 2013 has more glowing lights and it's focus is much better than cuore.
bro running rich means its petrol and air mixture is messed. more petrol and less air. very few mechanics understand it.
100W bulbs on stock wiring? That is very dangerous. They can burn the wires. Besides, imo I don't think the alternator can provide enough power to charge the batteries whilst supplying the power to the 100 watt bulbs U might end up with a depleted battery in some time.
Refresh:D
Anyone selling cuore automatic??
Why this place is sooo quiet from so long????
i am talking about the periodic / preventive maintenance.let's suppose that the car has a history of following the periodic maintenance schedule, then what should one inspect / replace at this much mileage.
Whenever I turn my cuore to right a tic tic sound can be heard, some one told me that its "GODA" is sounding like TIC TIC Can any one suggest that from where I can get it fixed ?thanx in advance
Cuore 'Goda'
https://www.pakwheels.com/forums/cuore-mira/249464-cuore-ka-goda-bar-bar-toot-jata-he
I have 2005 model manual Cuore and I am having no problem in driving. I want to take it to Murree. Two mechanics suggested me that its clutch plates are weak and don't take it to hilly areas without getting clutch plates changed. But I am doubtful about that because I took it on Motorway and GT Road many times without any problem.
Assuming that it is an old car, relatively, and its clutch plates are weak, then what can be the problem if I take it to Murree ?
slipping clutch plates on long route will make it heat up fast and it will be power less when all friction material is gone. changing clutch takes one full day.there is no issue of old car. before you leave get the car checked from lower side. also brakes.
