Results 1 to 6 of 6
Thread: cuore rpm drops with delay
    driver_guy's Avatar
    Jan 2007
    37
    219
    Default cuore rpm drops with delay
    I have a problem with cuore 2006 rpm drop delay. After giving race and lifting foot off the pedal, first the rpm drop to a certain level then hold for about 2 seconds and then come down to idle.
    What can be the reason?
    sarsalan's Avatar
    Jul 2013
    30
    194
    2 Post(s)
    Quote Originally Posted by driver_guy View Post
    Running on CNG or petrol ?
    driver_guy's Avatar
    Jan 2007
    37
    219
    Quote Originally Posted by sarsalan View Post
    It is same on both petrol and cng
    sarsalan's Avatar
    Jul 2013
    30
    194
    2 Post(s)
    two things u need to get checked...
    1. ur pull spring on the pedal..
    2. u might have to get ur kit tuned...when was the last time u got ur CNG kit tuned ?
    driver_guy's Avatar
    Jan 2007
    37
    219
    1- I also checked by revving from the throttle lever attached to the carb, problem is same
    2- Do you mean cng kit cleaning? or cng mixture setting?
    sarsalan's Avatar
    Jul 2013
    30
    194
    2 Post(s)
    mixture setting...dont do it urself unless u knw wht ur doing..go to a certified tech guy..he will set it up and u might also need to get the carby checkd out..
