Results 1 to 5 of 5
Thread: cuore Mising on CNG. Experts plz help
    faheem14's Avatar
    Mar 2011
    177
    Default cuore Mising on CNG. Experts plz help
    Cuore2006 is mising on cng and if i put ac on its do mising more i went to my regular mechanic he did tunning 2 times in last few days, change plugs, point etc but all in vain. Plz tell where should i go now , i live in dha area lahore.
    Regards
    shumsoh's Avatar
    Apr 2011
    224
    2 Post(s)
    I suggest you to go toyota showroom, they will charge you 800/- but beleive me they are best in cng settings of cuore because cuore is toyota baby.
    j12johny's Avatar
    Jul 2013
    12
    Quote Originally Posted by faheem14 View Post
    Regards
    bro go to any good cng pro they will solve your prob
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    change the ignition coil or desi totka bypass resistance will will solve ur problem
    faheem14's Avatar
    Mar 2011
    177
    Problem is sloved by toyota airport motors. Distributor cap replaced, Oil in 1 plug due to timing out, Plugs replaced and timing adjusted. Engine is getting weak as it crossed 2 lac kms.
