Results 1 to 6 of 6
Thread: Experts Suggestion needed for engine oil of MIRA 2010 CVT
    faraz99's Avatar
    Apr 2013
    87
    Question Experts Suggestion needed for engine oil of MIRA 2010 CVT
    Experts are requested to suggest best engine oil for Mira 2010 CVT, currently i use Caltex Havoline and i change it on every 2000 kms, and is it necessary to install a new oil filter on every oil change? and also when to change the air filter? plz suggest.
    john0995's Avatar
    Jun 2008
    Hari pur
    1,532
    17 Post(s)
    brother agr oil ziada blakish hojaey to filter bhe change kar dia karen
    CoMmiNg SoOoOoOoOoOoOoOoOn
    faraz99's Avatar
    Apr 2013
    87
    john bhai, yani har oil change pe filter change hona chahiye na?
    hassan.ellahi's Avatar
    Dec 2010
    1,164
    20 Post(s)
    2 Thread(s)
    Bro you don't need to change the oil at 2000kms! Atleast use it for 3500-4000 kms and yes you should change the oil filter on every oil change
    faraz99's Avatar
    Apr 2013
    87
    bro i change it because my car has some heating issue, and its rpm always runs on 2500 to 3000 on below 100 speed. Thats why the engine heats up. So i change the oil on every 2k. Now what do u suggest? And also suggest me good oil please. Is the havoline fine or i try different one?
    faraz99's Avatar
    Apr 2013
    87
    experts please.
