Results 1 to 4 of 4
Thread: Cuore engine
    enthusiasticracers's Avatar
    Aug 2008
    22
    63
    Default Cuore engine
    My 2002 Cuore is on its last legs. Engine is down. There was a spark plug failure a few days ago and when I took it to the mechanic he said that the 'rings' (piston rings I guess) needed to be replaced. I was thinking of changing other things as well like the piston valves and whatever there is to it as I am sick and tired of the bogged down performance. How much will that cost me??
    (Bear in mind that I only want to change the engine parts not the entire engine)
    nfssaad's Avatar
    Oct 2006
    29
    3,179
    50 Post(s)
    what you will be doing is a top end overhaul.. includes head rework. new valves , valve seats and seals. new rockers if needed. new valve guides.
    pistons rings will also be changed... while pistons are out see the condition of the cylinders. if the honing marks are worn out the cylinder will have to be rehoned. if too much rehoning is needed than you will need new pistons.
    any how a top end would set you back around 15k..
    the problem is not our govt... its the people..
    Aug 2008
    22
    63
    And how much will a complete overhaul cost?
    own a Toyota but move it like a Ferrari
    Aug 2008
    22
    63
    Also can you tell me a good workshop from where i can get this done in karachi?
