Results 1 to 6 of 6
Thread: Cuore petrol problem 2000 model
    Newbie Follow
    asharfraz's Avatar
    Dec 2013
    Default Cuore petrol problem 2000 model
    AoA
    i am totally a newbie
    i am stucked with a problem,
    i have using my car with cng
    now i used it on petrol,
    scenario
    when i convert and start
    it goes well but keep missing
    after running a while,
    it gives shocks and turns off,
    after 5 to 30 monutes, when i ignite again
    it gets started.
    please suggest the solution.
    JAZAKAALH
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    had similar problem
    can be something as minor as air getting in the fuel lines
    my cars fuel tank was rusted
    rust was clogging things up and car used to shut off
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    additional things i checked in the process
    carby was taken out and serviced,
    fuel pump
    fuel filter
    silent833's Avatar
    Jan 2011
    151
    CHECK UR fuel filter
    usman_haider84's Avatar
    Mar 2013
    98
    4 Post(s)
    first of all service ur carby and then check d fuel pressure by pulling out d pipe .if pressure is ok then change d fuel filter.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Get the fuel pump checked,it could be weakened.
    Never loose hope in life,every step gives u something.
