Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Like Tree4Likes
Thread: ELM 327 Settings for Daihatsu Mira
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Default ELM 327 Settings for Daihatsu Mira
    Friends, I need help with setting up ELM327 bluetooth adapter on my Daihatsu Mira 2007 (L275) either Torque Pro or HobDrive..I have tried many options but no success..with ignition on./engine running.the adapter worked on City and professional scanners connect to Mira.
    Error is Can't connect to the ECU..
    I have searched a lot but could not find what protocol Daihatsu Mira uses..Please help Im desperate to connect it..have both paid apps HobDrive and Torque. Appreciate response.
    waleed911's Avatar
    Sep 2011
    485
    16 Post(s)
    Quote Originally Posted by zeeshan368 View Post
    If you are using android use obd car doctor... it will try to match the protocol... it worked with my vitz better than hobdrive...
    Cheers...
    Sent from my SM-T310 using PW Forums mobile app
    Driving is not about going from point A to point B, it is the point...
    ghosta's Avatar
    Apr 2012
    139
    6 Post(s)
    you can give a try to car guage pro android app it work on passo pretty well & it have option to select jobd protocol
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    ELM 327 is not compatible with the diahatsu mira 2007 .
    roomi351's Avatar
    Apr 2009
    31
    227
    4 Post(s)
    Aoa i need a obdi port connector to connect my prous with iphone n scan the car
    roomi351's Avatar
    Apr 2009
    31
    227
    4 Post(s)
    Can anyone tell me from where i can get
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    edit -
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    you sure? should i stop trying?
    Quote Originally Posted by atta1111 View Post
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    yes dear it does not work with the mira had done much R&D on it 3 year's ago.
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    thanks
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    this elm327 bluetooth adapter with CD condition 10/10 is for sale as of no use for me.
  12. #12
    roomi351's Avatar
    Apr 2009
    31
    227
    4 Post(s)
    Zeeshan can it be used in prius
  13. #13
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Quote Originally Posted by roomi351 View Post
    i think yes..coz it worked on city and corollla and toyota jdm
    Sent from my GT-I9100 using PW Forums mobile app
  14. #14
    imranuh's Avatar
    Mar 2013
    29
    648
    18 Post(s)
    Elm 327 wont work with JDM cars
    P.S personally tried and tested on various JDM and pak Suzuki cars
    Sent from my Nexus 7 using PW Forums mobile app
  15. #15
    jehanzeb109's Avatar
    Jul 2005
    36
    229
    4 Post(s)
    Does it work on city IVTEC ??
    Sent from my G1 using Tapatalk
  16. #16
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Quote Originally Posted by jehanzeb109 View Post
    yes..tested on city 2010 . works
  17. #17
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    So it finally worked when i got Mira 2011.....
  18. #18
    whiteangel's Avatar
    Nov 2005
    2,240
    9
    65 Post(s)
    What type of Mira do you have? Do you think this will work with Mira Custom 2010
    Never argue with an idiot, they drag you down to their level and beat you with experience.
  19. #19
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    I have CVT 2011 and its works goood... i think shld work with 2010.
    It did not worked on 2007
    Quote Originally Posted by whiteangel View Post
  20. #20
    m.raheel's Avatar
    Feb 2015
    23
    Zeshaan bhai elm 327 ABS EPS AIRBIG bhe scan karta hai
Tags for this Thread
