Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: cuore resistance
    TariqArshad's Avatar
    May 2011
    58
    Default cuore resistance
    Some times when my car doesnt start in the morning then I put a wire on the resistances terminal or you can say "direct krta hn terminal ko" and it starts normally and works fine all day.I have changed its resistance once but after a month or so today it showed the same problem.Any suggestions?
    But to personally satisfy my own adrenalin needs, I've been racing cars a little bit, which has been fun.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    I beleive you are talking about the ignition coil.
    The original wiring is setup in a way that the resistor is bypassed and "full current" is supplied to the coil during "start" This wire originates from the starter solenoid. If its missing you can install one yourself.
    gujar96's Avatar
    Sep 2012
    Rawalpindi
    32
    895
    19 Post(s)
    What are symptoms of a failing ignition coil?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by gujar96 View Post
    stumble upon load, failure when hot etc.
    May 2011
    58
    Yes,I am talking about ignition coil.Can you explain it with illustration about the installation you mentioned earlier.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    Its a generic diagram, small cars have this from the starter solenoid small wire.
    cuore resistance -1356369
    The diagram on the right is for you.
  7. 11-02-2014, 10:59 PM
    Senior PakWheeler
  8. #7
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    In my suzuki carry van Suzuki Motor House just bypassed the resistor
    93 Accord CB7 (Sold) / 2005 CL7
  9. #8
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    bypassing the resistor on a low impedance coil will burn out the CB points (point). The amp load is too high. The coil will also burn out early.
