Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By muneebhussain86
Thread: rpm struck and then drop very slow
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Default rpm struck and then drop very slow
    after releasing accelerator, rpm stay high for 3-5 seconds and them come back to idle very slow. a mechanic told me that i should get butterfly serviced. i want to ask that can this problem fixed with using carb cleaner or wd40.
    for example if i press padle at nautral to 3k rpm and release, it will come to 2k rpm and stay there for 3-5 seconds. then it comes back to idle slowly.
    car is cuore 2005. mileage and starting is fine. problem is coming for few weeks.
    muneebhussain86's Avatar
    Apr 2012
    38
    lubricate the throttle cable.
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    yes i did not think in this direction. will do it.
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Also check when you press throttle does it comes slow to its default place
    93 Accord CB7 (Sold) / 2005 CL7
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    checked by removing throttle cable. problem persists. found out that after pulling and releasing lever, it is not going back fully. by eye it seems as it is back but with a little push from finger it makes rpm fine. this lever is connected to lot of mechanisms. by standing in front of engine, at left maybe is mechanism that movies with it to control gas.
    Quote Originally Posted by afnan.bashir View Post
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by meh1 View Post
    May be its the issue of Lever Spring
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Just oil the butterfly shaft at the pivot ends and move it vigorously for about two to three minutes,hope it will resolve the problem.
    Never loose hope in life,every step gives u something.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Auto choke is jammed
    Sent from my GT-I9105 using PW Forums mobile app
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    i have bought carb cleaner and wd40. will use it generously in morning. outside and inside
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    used carb cleaner to no use. and then wd40 and still no improvement. i think last option is to get carburetor serviced.
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    I also have this problem whenever u start my cultus (2012 model) the rpm goes to 2 to 2.5 k then drops slowly what could be the problem?
    Sent from my Desire HD using Tapatalk 2
    4 wheels move the body 2 wheels move the soul
  12. #12
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    mechanic diagnosed me that 'Tikki' or butterfly needs to be serviced. i believe there is a mechanism inside carburetor that closes it slowly like a soft eject and it is not working good. but cultus 2012 is EFI.
    Quote Originally Posted by Shafin619 View Post
  13. #13
    Shafin619's Avatar
    Sep 2012
    21
    2,699
    95 Post(s)
    2 Thread(s)
    Yeah my cultus is new with only 23k on odo
  14. #14
    Apr 2012
    38
    there is vacume problem with the auto choke.
    tight the screw of auto choke for temporary resolution. but it wont start in morning without pressing the gas padel.
    Drive, Eat and Sleep
