My car's idle stop was not working. Same issue was here,the green indicator shows on,then car turns off when stopped, when j put ur feet of brake pedal,it doesn't starts.
I checked every known electrition,no one found the solution, because our electritions are illiterate.
First thing u do us change the main battery of car.u must put in dry battery only then it works.u can borrow it from someone for sometime.
My car started working now.
If this doesn't work.I got repaired my idle stop from "onspot inspection".u can aslo found it on fb.they will charge u 3-4k.but believe me,they will find out the solution.
