Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By sheikhmunda97
Thread: Mira 2008 Ac problem
    s.ahmad.zaidi's Avatar
    Sep 2013
    23
    12
    Default Mira 2008 Ac problem
    hello everyone please recoment a good compressor for my 2008 Mira. the ac stops blowimg cold air while i am on traffic light or the car is just switched onn but not moving.
    pls pls help ne and guide me where to go other than Punjab Car Ac. i have already wasted almoat Rs 11,000 on them
    usman_arooq2's Avatar
    May 2011
    Sialkot
    1,437
    13 Post(s)
    Quote Originally Posted by s.ahmad.zaidi View Post
    do confirm if ur car has overheating issues and condenser fan is working properly.
    Bella, You give me everything just by REVing - NEONLIGHT SAGA: NEWTUBE
    Sep 2013
    23
    12
    no the car has no heatimg issue and fan works properly. i have checked with 3 AC workshops and all f them have recomended me with Duet compressor and new condonsor
    May 2011
    Sialkot
    1,437
    13 Post(s)
    the problem u mentioned could be due to 2 reasons.
    1. the ecu trips the compressor more often due to some fault in system.
    2. the condenser is not getting cold air flow while u are stopped. either due to a non working fan or due to excessive heat from radiator doesn't let it cool properly.
    and what jobs did punjab ac did on ur car and what was the result????
    Site Banned Follow
    aussie112's Avatar
    May 2008
    Baku
    33
    20
    Can you explain each and everything that Punjab Car ac did for the Rs. 11,000? Also, here is a quick tip. Park your car and run the engine. Turn your AC on and turn the blower fan to full. Look for the High Side Sight Glass. There should be a grey cap on your high side AC line from the compressor. It should be on the right side next to your right headlamp.
    If you look at the sight glass, it should be either clear or you should see bubbles. If there are bubbles coming, that means your R134a refrigerant gas is low. If it is clear, then your refrigerant gas is normally full.
    I am guessing that your R134a refrigerant gas might either be near empty/low or possibly overfilled. If the refrigerant gas is low, and they have NOT properly filled the refrigerant gas to the exact amount by WEIGHT, then your compressor will overheat and trip the pressure sensor. The other issue could be that your magnetic clutch on your compressor is not activating, which could mean a bad relay.
    Can you tell me what all Punjab Car AC did and then I can guide you on what to do? I am in Lahore, so if you would like to show me your car, then I can help you sort it out. I can get the service manual and see what it says.
    Let me know. Thanks.
    huzaifa.haroon's Avatar
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Check the foam between radiator and condenser , none of a/c workshops check that and most of time in accidental jdms that is the problem!
    Do it yourself
    "Never forget the favours done for you.Always forget the favours you've done for others"
    Always respect your parents
    Sep 2013
    23
    12
    Punjab car ac just replaced my comp and charged mev11000 and after almost 2 months the gas srted leaking. Now i have checked with 3 other AC workshops and all of them have told me same thing that Mira's orignal comp is not good for Pak. You should replace it with DUET comp and withbnew condensor
    Aug 2012
    5,001
    10
    225 Post(s)
    7 Thread(s)
    Never happened with me but check shrout and foam btw radiator and condensor
    "Being critical doesn't mean you care.Being helpful does"
  9. 03-05-2014, 03:28 PM
    Senior PakWheeler
  10. #9
    sheikhmunda97's Avatar
    Nov 2011
    Kasur
    1,686
    8 Post(s)
    Ye to hona he tha
    ALONE
    BUT HAPPY
  11. #10
    fahadwizz's Avatar
    Feb 2011
    35
    2,383
    52 Post(s)
    3 Thread(s)
    if its heating up ecu will trip compressor to prevent it from over heating. common problem with mira and our champion AC walas will make u replace parts parts until the whole thing is replaced with a jugaro setup. In the end they will just jump the climate control harness and make the ac direct like in older cars. You will enjoy the cold air for sometime and eventually run into engine heatup problems.
    Checking compressor functionality is very simple. any ac wala will do it. if the compressor is engaging but not cooling only then its shot. if its not engaging then the problem is somehwere else. if the compressor is shot to this extent you will most def need a new condensor. I would suggest u hook up an OBD II device and cehck your engine temps when the ac trips.
