Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: hot starting problem. need urgent replies
    ismaildesai's Avatar
    Dec 2011
    37
    Default hot starting problem. need urgent replies
    my cuore 2003 starts in half self on cold startup. but after shutting down or warming up the engine and shutting down the engine it refuses to start. engine rotates but does not start. sometimes it starts.After leaving it for 10- 15 min it starts right up. its carb was overhauled and auto choke was removed. it vibrates on cold start and have to keep the race pedal pressed until warm up. on cold start some black soot falls from tail pipe along with water.
    need help
    Dec 2011
    37
    by d way im using it only on cng
    aamirq's Avatar
    Oct 2006
    31
    1,726
    26 Post(s)
    u need to get the cars tappets adjusted and the cars engine coolant sensor checked!
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    can only be diagnosed when its actually happening.
    mechanic would check current and fuel supply when car is warmed up and not starting up
    auto choke needs to go back to stop vibration on cold.and the black smoke is a sign of rich mixture
    warewolf1's Avatar
    Jul 2009
    Other
    34
    374
    2 Post(s)
    Seems like a self starter problem. Get it checked. May be its bushes need replacement.
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    How happy is the blameless Vestal's lot... The world forgetting, by the world forgot.
    Eternal sunshine of the spotless mind... Each prayer accepted, and each wish resigned...
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    Just Install Relay on CNG kit..
    Pakistan <3
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    could be small as a fuse going kaput in cng kit
    change the fuse ASap
    Hanjiii Kaa Storeey Eehh !
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    it sulf problem not cng, tapered fuel line or any thing else go to any car electrition n ask about this problem, 15 mints work.
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Quote Originally Posted by harib4u View Post
    Its that fuse in CNG lit
    Sent from my A10 using PW Forums mobile app
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    Quote Originally Posted by ekdrifter View Post
    no cng related problem once my petrol mehran 2010 got this problem thats why i know about this problem. when small carbons n bushes in sulf got hot it make problem starting, like you feel battery almost dead when you start, but if you start it after 20-30 mint it start very quickly half sulf start.
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    I think that might ne true but not in this case as he drivrs on cng and that fuse thing happend many times to my mehran ex and recently to a friends cultus
  12. #12
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It could be because of incorrect tappet clearance and weak ignition coil,get it checked accordingly.
    Never loose hope in life,every step gives u something.
  13. #13
    Dec 2011
    37
    The engine rotates without hesitation, this means self is ok and if i push strt it when hot , it starts . Mechanic by passed coil resistnce to chck and it strted but he was not 100 sure wheter it is coil problem. No blck smoke . Just some soot falls from tail pipe o n cold strtup.
  14. #14
    Dec 2011
    37
    Where is coolnt sensor and what is the function of it
  15. #15
    Dec 2011
    37
    Curent chcked. Ok
  16. #16
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    check the coil resistor with a multimeter and check that its wired up correctly, there should be 1 wire coming from the starter solenoid trigger directly to the coil bypassing the resistor - this causes the coil to work on full battery voltage - creating hotter sparks for startup.
    If you pass this test then check for vapor lock, remove the fuel intake pipe at the fuel pump and see if it blows out a lot of vapor.
  17. #17
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    can be a fuel filter problem too.
  18. #18
    Dec 2011
    37
    iam using car only on cng. and when resistor was bypassed it starts on long self
  19. #19
    Dec 2011
    37
    Quote Originally Posted by ismaildesai View Post
    what happens when there is no wire from starter to resistor. does engine start?
  20. #20
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    that would be a very hard start.
