Results 1 to 6 of 6
Thread: Daihatsu Mira 2010 L275s ABS Actuator Damage.
    hassan1214's Avatar
    Nov 2006
    30
    9
    Default Daihatsu Mira 2010 L275s ABS Actuator Damage.
    I have Mira 2010 Model Having Chasis no: L275s.
    My Mira is 2wd.
    Mira 2wd ABS unit Number is DL101 89540-B2190.
    I have 4wd ABS unit Number is DL102 89540-B2200.
    Both ABS unit are 100% identical.
    Now the problem i am facing is that my speedometer is not working.
    Mechanics told me that you have to replace the ABS unit otherwise there is no way to run your speedometer.
    ABS unit are hit few days ago motor cycle thats why speedo meter is not working.
    Now i have 4wd ABS unit looks 100% same as 2wd ABS unit.
    Is 4wd model ABS unit will compatible or works with 2wd model ?
    Please suggest.
    Actually i dont want to change my ABS unit because its very expansive....People in Bilal Ganj Demanding 25k to 28k.
    Is there any way so i can run my speedometer?
    Need suggestion from experts.
    Similar Threads:
    • #2
      capsat's Avatar
      Apr 2006
      Select City
      10
      12,597
      31
      6
      1018 Post(s)
      19 Thread(s)
      5
      6
      as soon as you hook up a 4WD ABS unit in place of 2WD ABS - The Check engine will lit up. however you can drive carefully couple of miles to test n see if speedometer starts to function or not. a desi tukka fizzin way
      - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    • #3
      hassan1214's Avatar
      Nov 2006
      30
      9
      actually i will order abs unit from japan...in japan abs unit of 4wd cost me only 3500 yen and 2wd model cost 8300 yen.....but both looks identical....there is a risk in ordering a 4wd abs unit because there is a chance of wastage of money.
    • #4
      meh1's Avatar
      Feb 2012
      Sahiwal
      1,361
      90 Post(s)
      why don't you ask Daihatsu or the dealer in Japan. if ABS unit has different part code for 2wd and 4wd, it is a risk.
    • #5
      hassan1214's Avatar
      Nov 2006
      30
      9
      Any one please give me address and number of a reliable spare parts dealer in peshawar and quetta, i there i can found a abs unit in reasonable price
    • #6
      hassan1214's Avatar
      Nov 2006
      30
      9
      anyone suggest me the spareparts shop name in peshawar or quetta where i can find the abs unit in reasonable price
