Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By nabeegh10
  • 1 Post By fezan.x
  • 1 Post By ahmed2396
Thread: Hard steering of cuore
    nabeegh10's Avatar
    Jun 2014
    33
    Default Hard steering of cuore
    Hi, i've recently buy cuore cl eco 2007. its steering is so hard.. what should i do? feeling worried :/
    surplusstock's Avatar
    Jun 2014
    2,301
    39 Post(s)
    3 Thread(s)
    What about tires. R they worn out?
    shafiaamer's Avatar
    Sep 2004
    Rajanpur
    37
    57
    Quote Originally Posted by nabeegh10 View Post
    Cheak eps
    nabeegh10's Avatar
    Jun 2014
    33
    Quote Originally Posted by surplusstock View Post
    No! Tyres are ok!
    nabeegh10's Avatar
    Jun 2014
    33
    Quote Originally Posted by shafiaamer View Post
    Cheak eps
    No eps in cuore
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    Steering get hard when the steering is repaired by lathe machine to improve stability. This gets required when steering worn out due to wear and tear. You may get used to it. If not then either buy a new steering or get EPS installed. My cuore 2008 now also has hard steering. Orginal steering of cuore is as soft as power steering. Check Cuore fan club thread for more information
    nabeegh10's Avatar
    Jun 2014
    33
    Quote Originally Posted by fezan.x View Post
    From where i can get the original cuore steering and what will be it cost?
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    No idea dear, check with local markets or search for some experts on forum, meh1 is a senior pakwheeler ask him for advise.
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    You can buy a good piece from scrap yard or known as kabuli steering and check for chimta and ends too they are also cause of hard steering and car loosing steering in pot holes and vibration in steering after 70km/h
    Site Banned Follow
    khjodat's Avatar
    Aug 2013
    53
    260
    10 Post(s)
    Check following things; check front wheel alignment. check tire pressure, it should be 30 psi, check tire wear out and change with new tires. check the size of tire, change to standard size, lubricate the moving parts of front suspension.
    nabeegh10's Avatar
    Jun 2014
    33
    Thanx every bdy for ur kind suggestions
  12. #12
    fezan.x's Avatar
    Nov 2013
    27
    104
    2 Post(s)
    Do let us know if your problem get resolved. All the best
