I have cuore 2007.. Pick up is not god especially in 2nd gear, although its a water droping engine.. Kindly tell me any remedy... Jab kisi speed breaker k bad 2nd gear pe uthata hu to engine blkl beth jata he
1st gear pe bhi koi khas pick up nai he
for how long you are having this problem? when u did tuning last time? seems like problem of weak clutch.
on idle put your car is 3rd gear if it stalls then your clutch is good but if it doesn't then your clutch is bad, check fuel pump spark plugs air filter oil filter and engine oil valve clearance engine timing.
