Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree2Likes
Thread: Oil and oil filter Mitsubishi mirage 2012
    kashrah's Avatar
    Oct 2008
    13
    Default Oil and oil filter Mitsubishi mirage 2012
    What oil is recommended for 2012 mirage and what oil filter can fit as original Mitsubishi parts r not available.. Is there any Mitsubishi expert who can do maintenance on these car since there is no dealership
    kashrah's Avatar
    Oct 2008
    13
    Quote Originally Posted by kashrah View Post
    Ok just to update oil filter for all Mitsubishi is standard so no issues there.. Recommended oil is fully synthetic 0w20 but even 5w30 from total also works fine..
    air filter is not available so my mechanic did some juggar with honda air filter to fix the problem.. Now only issue is CVT transmission Fluid J4 is not available .. So looking for alternates.. Have heard that toyota CVT Fluid works fine.. So will look into that...
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    2.8 litre without filter & 2 litre with change of filter 5w-30 is oem recommended engine oil for Mitsubishi 3A92 engines. Shell Helix Ultra Extra will serve the purpose. - Check from Modern Motors they can guide you correctly for Mitsubishi - or contact Sherwani Motors in Karachi
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    kashrah's Avatar
    Oct 2008
    13
    Quote Originally Posted by capsat View Post
    Hi Thanks for he update, I called sherwani but they are not working on mirage... were is Modern Motors can I also have their contact number.
    aliadnan1984's Avatar
    May 2015
    175
    6 Post(s)
    Mitsubishi 3S dealership is under dewan motors . I found this website : DMMC | Dealers
    according to it :
    Lahore : Mitsubishi Momentum Motors , 23-A , Queens Road Lahore , 042 36300615
    Similarly there are in Karachi, Rawalpindi , Islamabad
    Plz note I am not a mitsubishi user i was researching it as Mitsubishi Mirage is looking good to me. Do tell what info you get from the 3S dealers .
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    AOA whats the update on mirage cvt transmission oil change. How & which oil used .
    Sent from my LG-D802 using Tapatalk
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    what gearbox is this car equipped with? does it have a JATCO? or Aisin?
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    JATCO CVT7
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    Quote Originally Posted by hello123 View Post
    JATCO CVT7
    DrUsmanNawaz's Avatar
    Jul 2011
    Wah cantt
    34
    3,939
    19
    165 Post(s)
    2 Thread(s)
    take advice from @drzac, recently he did quite a research about the MIRAGE....
    nomanturk1's Avatar
    Dec 2008
    36
    30
    Toyota cvt fluid will work fine with jatco cvt transmission...
  12. #12
    nomanturk1's Avatar
    Dec 2008
    36
    30
    Other option is amsoil cvt fluid... But check with amsoil dealer/distributor for availability...
    Here is dealer contact info:
    Cinq Astre Enterprises
    101 Bank Square Market, Model Town,Lahore-54700
    Pakistan Phone:+92-42-35832361 Cell: +92-321-4111447
    Email:sales@cinqastreenterprises.net
    Email: cinqastreinc@gmail.com
    Direct for Automobile: +92-42-35881875
    http://www.cinqastreenterprises.net/AMSOIL.php
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    JATCO CVT7
    you need something like nissan ns2 - the toyota one may or maynot work. It wont be like - you put it in and boom goes the gearbox, but its friction characteristics maybe different.
  14. #14
    hello123's Avatar
    May 2009
    112
    3 Post(s)
    Thanks for reply. Amsoil distributor in lahore is outta stock but ordered amsoil cvt fluid & would be available in 50 days approx. Amsoil cvt fluid as per their website compatible with jatco (cvtf j4) cvt & ns3 & suzuki green 2.
  15. #15
    nomanturk1's Avatar
    Dec 2008
    36
    30
    Oil and oil filter Mitsubishi mirage 2012 -1618714Oil and oil filter Mitsubishi mirage 2012 -1618715Oil and oil filter Mitsubishi mirage 2012 -1618716Oil and oil filter Mitsubishi mirage 2012 -1618717Oil and oil filter Mitsubishi mirage 2012 -1618718
  16. #16
    nomanturk1's Avatar
    Dec 2008
    36
    30
    How is she'll helix ultra 5w 40 engine oil for mirage? Any problems?
  17. #17
    nomanturk1's Avatar
    Dec 2008
    36
    30
    This is how we can check CVT transmission fluid level and condition.
    Oil and oil filter Mitsubishi mirage 2012 -1620691
  18. #18
    nomanturk1's Avatar
    Dec 2008
    36
    30
    Honda oil filter fits perfectly in mirage
    Honda part No:15400-RTA-003
    Price: Rs.950
    http://www.hondapartsnow.com/genuine/honda~filter~oil~15400-RTA-003.html
  19. #19
    mohammed_ahmed's Avatar
    Jul 2014
    60
    2 Post(s)
    Sorry for going a bit off topic question but after reading thru I think you ppl can help me ..
    Which cvt oil is works well for Toyota aqua available in Pakistan
  20. #20
    nousher101's Avatar
    Nov 2013
    33
    177
    3 Post(s)
    Quote Originally Posted by mohammed_ahmed View Post
    Name:  ImageUploadedByPW Forums1443181318.799116.jpg
    This one
