Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Like Tree2Likes
Thread: Daihatsu Mira X Limited CTV Transmission Fluid
    tab001's Avatar
    Nov 2014
    53
    Exclamation Daihatsu Mira X Limited CTV Transmission Fluid
    I have Daihatsu Mira (X-Limited 2010 Model), when bought it was already 34000 KM on odo and now its 40700 KM. I want to change its transmission fluid as Change due on every 20000KMs. Now I am searching for the compatible CVTF fluid oil for my car Mira X-Limited (2010).
    i have attached the dipstick screenshots where the fluid name is mentioned in japanese. I have tried to translate it using Google Translator and found that it is Daihatsu Amikkusu CVTF Fluid DC (Ammix CVTF Fluid DC).
    Here I need help from you expert ppl that:
    1. Am i right that in Mira X-Limited, the transmission oil would be Daihatsu Ammix CVTF Fluid DC ?
    2. Does anyone change the Transmission fluid in his/her Daihatsu Mira CVT car ?
    Thanks For your help :-)
  2. #21
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Hi
    Is the Toyota CVTF TC working good in your car? how much was replaces? liters i mean. I have to change CVTF of my Mira X 2011.
    Quote Originally Posted by tab001 View Post
    Is it available in Pakistan ? Or needs to import ? BTW i have changed the CVT oil and used Toyota CVTF TC in my Daihatsu Mira X Limited.
  3. #22
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by bilalahm View Post
    Japanese vs German......... you decide :-)
    if deciding on nationalities then americans are pretty good at blending lubricants, german are not, the german domain is metallurgy and design.
    Japanese are famous for making a design low cost.
    rest aside.
    use the manufacturer recommendation - in this case its a dai/toyo problem, both are the same
