Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Like Tree21Likes
Thread: CVT Transmission: "D" is blinking while turn on the engine
    tab001's Avatar
    Nov 2014
    53
    Exclamation CVT Transmission: "D" is blinking while turn on the engine
    <b>Daihatsu Mira X Limited 2010</b>
    I have noted that since last few days, as i turn on the engine, on odo meter, the PRNDSL is blinking as:
    When On "P", Blinks "P" to "D" (like P D P D P D)
    When On "R" => "D", Blinks "R" to "D" (like R D R D R D)
    When On "N" => "D", Blinks "N" to "D" (like N D N D N D)
    When On "D" => Just blinking
    When On "S" => "D", Blinks "S" to "D" (like S D S D S D)
    When On "L" => "D", Blinks "L" to "D" (like L D L D L D)
    Please suggest,
    Is there any issue in CVT Transmission ?
    If there is any issue what kind of of issue it would be ?
    Any Specialist of CVT in karachi ?
    Thanks in Adv.
    tab001's Avatar
    Nov 2014
    53
    FYI, My brother pulled out the battery for cleaning purpose. Is this could be the reason ?
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    Is it City IDSI VARIO? Which car are we talking about here?
    tab001's Avatar
    Nov 2014
    53
    I have edited the post. Its Daihatsu Mira X Limited 2010.
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    Quote Originally Posted by tab001 View Post
    Have you changed CVT oil? If not have it changed asap. Blinking D mostly means transmission failure. Have your car scanned for specific error codes or try resetting the ECU. Pull out the negative cord of battery first and than positive cord. Wait for 30min although actual time is 10min but being on safe side keep it disconnected for 30m.
    Than connect the terminals in reverse order positive first and than negative.
    Start your car and drive it around as if you do on daily basis for 30min. See if problem is eliminated if not than have its oil changed and scanned.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    open the bonnet and check for connector over the transmission, possible lose electrical plug. - also as other respected member suggested transmission oil change is squarely recommended across the forum [ by xulfiqar, syncview, argtr65, rustam54 margallar, Naweed ] for JDM vehicles landing in Pakistan.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    tab001's Avatar
    Nov 2014
    53
    Not yet change the CVT Oil, but i am searching for compatible CVT Fluid for my car. Odo meter reading is 40870 KMs and as recommended in the Mira Manual, oil change is due on 50000 KMs (in another post Xulfiqar mentioned CVT oil change 80000 KMs for first time and then on every 50000 KMs)
    Today, i will scan the car to find the error code.
    tab001's Avatar
    Nov 2014
    53
    I pulled out the battary for about 30 min as mentioned but the prb exists as it is. As i set the battary and turn on the ignition, blinking of "D" was there.
    Where could i find the CVTF for mira x limited in karachi ?
    khiju91's Avatar
    Jun 2014
    12
    Go to Khan motors phase 2
    kalia's Avatar
    Jun 2008
    32
    497
    23 Post(s)
    Please suggest,
    Thanks in Adv.
    I had this problem and yes, I had a battery issue but it was coupled with the low transmission oil. I went to Toyota and bought the standard 4L Teen Dabba CVT oil and have not faced any problem since. However, I agree with the poster's suggestion to get your car scanned. 500 rupees spent can save you a lot of trouble later.
    Do in pindi as the pindi boyzes do !!
    tab001's Avatar
    Nov 2014
    53
    I just came from Toyota Service center at Khalid Bin Waleed Road, they checked the oil condition manually and said oil is ok and upto the required level. But they did not scanned the car as they have not such software for Daihatsu Mira to read the codes related to CVT.
    Kalia, what type of battery issue ? I am facing this issue since the day, my brother pulled out the battery and clean the area around battery by using a cloth (kapray se jharaa)
  12. #12
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Check For Any Loose Connections Or Its Indicating A Bad Sign Of Transmission.....You Feeling Any Strange Behaviour After These Lights ??
    Any Sound From Transmission etc??? If Its all ok and driving Ok then manually check for all grips....
    it can be anything from loose connection to ATF change To bad solenoid/sensor to bad or slipping tranny.....!
    Try looking for scanner who can scan .....and replace ATF ASAP....its already due...don't wait and believe on Km's....changing ATF just 6000 early km won't do any harm but keeps your tranny on safe side....!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  13. #13
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by SER_GTR View Post
    No, i m feeling no difference in driving behaviour. even my fuel avg also same. just blinking D annoying me.
  14. #14
    tab001's Avatar
    Nov 2014
    53
    I scanned the car and the message came on the scanner was "Switch Pressure Sensor (Low)".
  15. #15
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    A good idea would be to stop believing that the 2010 model import is actually driven 40870 KMs and change the tranny oil ASAP.
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
  16. #16
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    which switch is mentioned here - @Xulfiqar @SER_GTR @syncview
  17. #17
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    what was the code?
    https://www.facebook.com/OsamaAbbasPhotography
  18. #18
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    What Is Code???? Like Pxxxxxx
    Seems Like A Code For Low Transmission Fluid Or Faulty Switch Itself.....You Need Oil Replacement B.t.w
  19. #19
    tab001's Avatar
    Nov 2014
    53
    I have scanned at 3 different mechanics and found the same error code "P0842 - Transmission Fluid Pressure Sensor/Switch A Circuit Low".
    <b>One of cvt mechanic told me that its ECU could be faulty and needs to be repaire or change. </b>
    I m also searching for compatible cvt fluid for my car daihatsu mira x limited but not yet found.
  20. #20
    tab001's Avatar
    Nov 2014
    53
    I have searched out the karachi market but could found the compatible CVTF for my car.
    Could a faulty ECU be a reason behind this blinking ?
    @Xulfiqar @SER_GTR @syncview @capsat
Tags for this Thread
