Results 1 to 4 of 4
Thread: Daihatsu Mira ES Eco Idle function
    mukry123's Avatar
    Mar 2015
    9
    Default Daihatsu Mira ES Eco Idle function
    Hi Guys.
    I have bought Daihatsu Mira ES with eco idle feature. It means that when I stop my car, the engine should shut down and when I release my foot from the brake it should start automatically.....but..... its not happening (seat belts are attached). Can someone guide me on this or suggest a good mechanic in Karachi who can tell me if something is wrong and needs fixing.
    Tahnxs
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    R u sure the airbags r intact?
    Laws r Made to be Broken
    usmkn's Avatar
    Mar 2007
    32
    13
    accidental JDMs have this problem, check that your seat belt stop with jerk or not? if free fix its lock and re-program its ECU.
    i have faced the same issue with my mira, got fixed from Jail road. This is not a big issue
    ovaiswaraich's Avatar
    Jun 2012
    Can u share the contact where u get ur eco idle problem fixed?
