Results 1 to 3 of 3
Thread: Mira eS Repair Works - Advice needed
    tasawwur's Avatar
    Feb 2014
    38
    Default Mira eS Repair Works - Advice needed
    My car got scratched by a trolley on passenger side front door and side mirror got dislodged too. Pics are attached.. I need advice regarding repair works
    1. As the mirror got dislodged, I think bracket might need to be changed and mirror might work fine as apparently there is no damage on mirror assembly.... so Replacement and Installation of Mirror Bracket.
    2. Denting of the scratched and dents plus painting.
    Expert advice is need as to from where can I get reasonable service at nominal cost. Cost estimate are also requested.
    margallar's Avatar
    Oct 2009
    9,958
    6
    283 Post(s)
    4 Thread(s)
    yes base of mirror can be replaced. go for dry denting and compound. find an expert dry denter
    haters gonna hate, potatoes gonna potate
    tasawwur's Avatar
    Feb 2014
    38
    Quote Originally Posted by margallar View Post
    Thanks... Do you know any good dry denting workshop in Lahore?
