Hi everyone. I have mira 2007, when i start the AC, car get too much load, means runing like JAM. please solve and suggest me
AC gas charging may solve or your compressor bearing is shot.
[h=3]Why does my car slow down when I turn on the a/c?[/h]
contact with car A/C Technician Mr. Haji Shakeel on 03234041972
Your car MUST be 3 speed auto , if so , it is normal don't worry.
check your rpm with ac setting, there is a race adjustment screw, check it
Faced similar problem, your compressor is shot..
A.C cooling in my car (jdm alto) is fine only problem is that when i apply the sudden brakes with a.c on the rpm suddenly drops car knocks and turn off. whats the remedy for that...
Clean the throttle body , rest the ecu by plugging out the battery cables and follow the idle lean procedure
