Results 1 to 14 of 14
Like Tree3Likes
  • 2 Post By s.ahmad.zaidi
  • 1 Post By s.ahmad.zaidi
Thread: AC gets off when brake pedal pressed
    muhammadfaham's Avatar
    Jul 2014
    22
    8
    Lightbulb AC gets off when brake pedal pressed
    I own a Daihatsu Mira Custom RS Turbo 2007. it has a turbo intercooler engine powered by 660cc engine engaged with CVT transmission..
    Now the question is when I press the brake pedal, AC gets off then it starts back.. this makes no sense, as when race/gas pedal is pressed aggressively it must get switched off... now when I am in stop and go position and in rushy area. AC frequently gets off making it impossible to beat the temperature.. Kindly help me what you say about it.AC gets off when brake pedal pressed -1576272AC gets off when brake pedal pressed -1576269AC gets off when brake pedal pressed -1576275
    CLick here for SOLUTION
    vickybhai's Avatar
    Aug 2005
    26
    2,448
    38 Post(s)
    it would have that smart stop feature which switches off the power from engine and transfers it to additional battery installed...
    1)Suzuki Mehran has changed its shape 2)Fake parts drive me nuts
    3)https://www.facebook.com/RoyaleEM
    Jul 2014
    22
    8
    but that should not happen. as it does not cool the interior cabin on braking. is there any way to stop this "smart feature" ?
    s.ahmad.zaidi's Avatar
    Sep 2013
    24
    12
    Default Don't worry
    I have 2008 Mira and it does the same. I got my gas totally changed by Suzuki motors. They have a machine which extracts all gas out and wastes it and later fills it with American gas. Your should do this too. It will increase your cooling. Secondly all 660cc cars have this issue to trip ac when breaks are applied or you acceleration is done. There is no problem with your car it's completely normal. You just need to get your ac gas refilled and serviced. Your, 80 percent problem will be solved
    zaybi31's Avatar
    Nov 2013
    Sialkot
    51
    my Suzuki Every's ac also trips when we put the transmision in D or when car stops and the transmision is in d..
    zeelaf's Avatar
    Jul 2005
    41
    711
    7 Post(s)
    The new Daihatsu Idle Stop System automatically stops and re-starts the engine when the vehicle is stopped at traffic lights and in traffic congestion to increase fuel efficiency and reduce noise when idling
    The AC switches automatically to ventilation mode. When you stop the car, the engine is continuously stopped. The duration and amount of fuel saved by ?idling stops? can be checked easily on a meter display during an ?idle-stop?.
    DAIHATSU - News
    Twin cam sixteen Vaalve da sticker Nikki jeyee gaddi utte
    dayrider's Avatar
    Mar 2006
    27
    1,908
    5
    16 Post(s)
    2 Thread(s)
    Quote Originally Posted by muhammadfaham View Post
    the odo meter normally has the option to disable these things
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    This model does not have eco idle so it is definitely an issue. Get your cars compressor and a.c. gas checked
    Laws r Made to be Broken
    Sep 2013
    24
    12
    Quote Originally Posted by dayrider View Post
    Have your tried doing it
    dayrider's Avatar
    Mar 2006
    27
    1,908
    5
    16 Post(s)
    2 Thread(s)
    Quote Originally Posted by s.ahmad.zaidi View Post
    I did it in the vehicles with eco idle or eco mode. The other vehicles don't have these issues
    zaybi31's Avatar
    Nov 2013
    Sialkot
    51
    i got repaired my suzuki every with the same issue today . and its just coil was changed which just costed total of 1500 rupez..
  12. #12
    Jul 2014
    22
    8
    Quote Originally Posted by zaybi31 View Post
    Excatly, when put in R, or suddenly in D and when brakes are applied this is so ridiculous
  13. #13
    saad.bukhari1's Avatar
    Dec 2013
    Multan
    25
    281
    4 Post(s)
    its the builtin issue in almost all every 660cc Japaneses car, i also faced it in my Mitsubishi EK wagon, and my friend's Japanese alto has a same problem, its not due to breaking it is mainly due to low RPM, since 660cc cars are under power cars therefore the compressor of these cars have been designed in such a way, which automatically turned off below certain RPM. during the time i have EK wagon i tried each n every thing but the problem remained unsolved, unless i had to sale it.
  14. #14
    Jul 2014
    22
    8
    what's exactly the coil is? and why its needs to bhi changed when AC works good in running condition
Tags for this Thread
