Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree1Likes
Thread: a question about car ACs
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    Default a question about car ACs
    in English:
    I want to know generally about all cars and specifically about Cuore that when we move the fan speed selector to medium and fast from slow, does it only speeds up the blow or is the AC working also sped up with this (and eventualyl more load on engine)?
    in Roman Urdu:
    mera sawal sab cars k ACs se related he or Cuore k baray main bilkhasoos hai. us main jb AC start karte hain to kya fan speed change karne se sirf blor k fan ki speed taiz hoti he ya AC bhi zyada cooling karna shuru kar deta he (and eventualyl more load on engine) ?
    SOLUTION
    VCheng's Avatar
    May 2010
    Select City
    25,479
    7
    434 Post(s)
    4 Thread(s)
    The compressor speed depends on the engine speed. The blower speed is set separately.
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    I am asking about the switch in the attached picture. (Slow/Medium/Fast). Does it only control the blower speed?
    a question about car ACs -1579655
    abdkhan2's Avatar
    May 2012
    Nowshera cantt
    504
    8 Post(s)
    5
    Quote Originally Posted by nabeelkhan View Post
    It control only the speed of the air blower nothing else.
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    does AC work on constant speed ?
    shaiki's Avatar
    Jun 2009
    46
    118
    The part that actually performs the AC function is the compressor. The compressor works at a constant speed and only takes away the heat from air. When you turn the knob on the AC panel, you are only changing the flow rate of the cool air. The AC/Compresssor works at a constant speed.
    -_-_-_-$*|-|*/\*|<*iiii_-_-_-_-
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by shaiki View Post
    Engine driven ac compressor work with engine rpm, the electrical ac compressor as in Prius work at a cabin temperature regulated speed independently.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,304
    49 Post(s)
    It depends on the system design. There can be a separate thermostat knob/slider switch. In modern cars the thermostat is also controlled along with the blower fan speed. I think in coure the selector switch you mentioned controls only the blower speed and the knob to its right has a mild option for economical ac which means ac will trip at a warmer temperature.
    And the compressor speed is directly proportional to the engine rpm as it is connected through a belt. Thats why at stopovers the ac performance degrades in smaller cars specially.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    huh?
    so decompression of the refrigerant aka boilover that happens in the evaporator is not the cooling function? or the condenser is not the item that removes heat?
    shaiki's Avatar
    Jun 2009
    46
    118
    huh?
    I was explaining the overall function of the air conditioning system not the whole air conditioning cycle.
    Yeah the refrigeratant absorbs the heat, vaporizes and then cools upon expanding through the capillary tubes. There is a whole work of thermodynamics behind it which I believed the poster wasn't interested in.
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    The fan speed control switch only controls the speed of the fan while the compressor's speed varies with the rpm of the engine and is not variable through some controller. However, the fan speed does alter the rate at which the compressor turns on and off, frequently turning on and off at low speed while staying on for longer at high speed. This happens because of the thermostat installed in the evaporator unit. At low speed, the coolness of the ac stays longer within the unit, making the thermostat think that it has reached the cut off temperature while at higher speed, it takes longer for the unit itself to reach the cut off temperature because the coolness is transferred to the cabin.
  12. #12
    nasirjavaid's Avatar
    Jul 2013
    3,083
    8
    77 Post(s)
    Quote Originally Posted by Owais_Yunus View Post
    Now that's what I was going to type... You save me from typing few words
  13. #13
    siraj_7's Avatar
    Jun 2012
    465
    10 Post(s)
    don't worry much about the blower switch, just set it at 4th place or 80% to save your self from cabin noise.
  14. #14
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    does that mean when car is running at high speed, the AC compressor works more and when the car is standing still but engine is on then the AC compressor works less ?
  15. #15
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    bhai ye samajh nahi aya mujhe. when you mentioned 'speed' several times is it car speed or fan speed? zara explain karo.
  16. #16
    Jul 2013
    3,083
    8
    77 Post(s)
    Speed of blower. It decides the tripping of the AC.
  17. #17
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    Quote Originally Posted by nasirjavaid View Post
    How it does that?
  18. #18
    Jul 2013
    3,083
    8
    77 Post(s)
    How it does that?
    Same as your refrigerator does when at low or high settings.
  19. #19
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    bhai mere blower ki speed ka AC compressor tripping se kya talluq
  20. #20
    Jul 2013
    3,083
    8
    77 Post(s)
    Bhai ha na talluq
