Results 1 to 2 of 2
Thread: Mitsubishi Mirage 2012 Dry AS&G Replacement Battery Required
    kashrah's Avatar
    Oct 2008
    13
    Default Mitsubishi Mirage 2012 Dry AS&G Replacement Battery Required
    I was wondering if someone can help we out and let me know what equivalent is available in Pakistan for my car as I'm not able to find a clear answer on the web. The car is Auto Stop & Go (AS&G) so I'm quite sure the conventional battery will not do. It currently has a dry battery so ideally I would like to replace it with the same. As per my understanding the Mitsubishi Model No is 55D23L. Kindly advise
    adnanikhan's Avatar
    Jan 2009
    35
    26
    Quote Originally Posted by kashrah View Post
    @kashrah........did u managed to get your answer if yes please share.............also let me know is there any dedicated battery for AS&G as cars like Mira have it or it works with the same main battery.
    @drzac...........do you have any idea ??
