Results 1 to 3 of 3
Thread: Mira LE-L250V 2006 Wiring diagram
    tmsahi's Avatar
    Aug 2014
    27
    11
    Default Mira LE-L250V 2006 Wiring diagram
    Aoa i am looking for L250V wiring diagram or if some one could help me with AC wiring with the ECU or ECU pin out for EF-SE engine. here is the ECU model that is installed with EF-SE Mira LEL250V 2006 Wiring diagram -1614698
    tmsahi's Avatar
    Aug 2014
    27
    11
    Bump any body who can help ??? 2ndly i am having an error code 54 i.e. starter sensor error i wanted to know that where exactly is this sensor connected to the starter motor ??
    tmsahi's Avatar
    Aug 2014
    27
    11
    Never mind i fixed the Errors 54,51,44,13 etc etc now i am only left with the AC connection with the ECU so if some can help ???
