Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Like Tree2Likes
Thread: Daihatsu Mira e:S Knowledgebase/Wiki
    integrale's Avatar
    Nov 2015
    7
    2 Post(s)
    Lightbulb Daihatsu Mira e:S Knowledgebase/Wiki
    I've painstakingly compiled all of this information, and I'd like to share it with you, but please don't copy information without giving due credit, or a link to this thread. Thank you.
    Ever since I've purchased my Mira e : S (2012, DBA-LA300S-GBPF, ~30,000km on clock), I've been scouring the internet and calling Daihatsu Service Centers in Japan for information that would help me understand my car better.
    I translated the Quick Start Guide from Japanese, and since I haven't been able to find a manual for the car through both official channels and the internet, I thought I'd compile a knowledgebase that I could refer to for information on my car, when I need it ? helping the community out in the process.
    Feel free to contribute any information you find, or share your experience regarding the cars, to help make someone else's life easier. I'll update this thread accordingly.
    I'll link facts that end up here to the author of the post highlighting that information.
    ## --- OWNER'S MANUAL DOWNLOAD --- ##
    Link to Daihatsu Support Website
    ## --- DAIHATSU MIRA E : S 2012 DBA-LA300S-GBPF --- ##
    Introduced: 2011
    OEM: ダイハツ (da-i-ha-tsu)
    Model: ミラ (mi-rah)
    Variants: Toyota Pixis Epoch, Subaro Pleo Plus
    Vehicle Assembly: Osaka, Japan
    Type: 5-door hatchback
    Engine: Daihatsu KF-VE3 658cc I3 (DOHC 12-valve, D-VVT, naturally aspirated)
    Bore x Stroke: 63.0 x 70.4 mm
    Maximum power output: 52 ps / 51.3 bhp / 38.25 kW @ 6800rpm
    Maximum torque output: 5.8 kgm / 41.95 lb-ft / 56.88 Nm @ 5200rpm
    Compression ratio: 11.3
    Transmission: Continuously Variable Transmission (CVT), 1-speed belt driven + creeper ratio
    Drivetrain: FWD
    Dimensions (l x w x h): 3,395mm x 1,475mm x 1,500mm
    Wheelbase: 2,455mm
    Curb weight (unloaded, dry): 730kg
    Rear suspension: McPherson Strut
    Front suspension: Torsion Beam
    Fuel tank capacity: 30L (2WD), 34L (4WD)
    Windshield washer tank capacity: 1.5L
    ## --- SERVICE INFORMATION --- ##
    Spark plugs: NGK SILKR6D10G (Iridium)
    Brake pedal play: 0.5–3.0 mm
    Idling RPM: 800
    Battery: M-42 High Performance Eco-Idle Battery (e.g. Panasonic Circla Kei Blue)
    Engine Oil: Daihatsu AMMIX SAE 0W-20 (factory installed) or 5W-30 (API SM or more)
    Replacement interval: Every six months, or every 10,000km (5,000km in severe conditions), whichever is earlier
    Replacement quantity: 2.7L exchange, 2.9L with oil filter
    Oil filter replacement interval: Every 10,000km (5,000km in severe conditions)
    Transmission fluid: Daihatsu AMMIX CVT Fluid DFE (recommended) / DC
    (Daihatsu insists that you only use this particular fluid. Take risks as you may.)
    Replacement interval: Every 50,000km
    Replacement quantity: ~2.4L drained, ~5.7L full capacity.
    Transfer case oil: Daihatsu AMMIX Hypoid Gear Oil SAE 80W-90 (API GL-5)
    Replacement interval: Every 100,000km
    Replacement quantity: ~0.57L
    Brake fluid: Daihatsu AMMIX (or DOT-3 equivalent)
    Air cleaner element replacement interval: Every 40,000km (20,000km in severe conditions)
    Coolant: Daihatsu AMMIX Long Life Coolant (pink) at 30% concentration (50% for cold areas)
    Replacement interval:First time every three, then every two years.
    Replacement quantity: ~3.2L
    Severe replacement conditions:
    Mileage of 20,000km/year or more
    Frequent short-distance (<8km) trips
    Sub-zero temperatures
    Tire size: 155/65 R14 (155mm width, 65 aspect ratio, radial construction, 14" diameter)
    (it's generally a good idea to not mess with these specs, because it'll upset the mileage of the car)
    Tire pressure (all wheels, all speeds, unloaded maximum): 260kPa, 37.7 PSI
    Tire tread depth: >1.6mm
    Rotation interval: Every 5,000km
    ## --- ECO-IDLE MECHANISM INFORMATION --- ##
    [in progress]
    UPDATE 2016-10-06: I've just found out a potential reason for my eco-idle not working. There's a very specific battery type made for "idling stop" cars that is required by my Mira. My Hankook isn't going to cut it. More testing required.
    ## --- INSTRUMENT CLUSTER INFORMATION --- ##
    [in progress]
  2. #21
    shazz_leo's Avatar
    Oct 2016
    Guys i am buying Mira E:s. Can anyone please confirm me the difference/s between the versions of the car. What is the difference between L version vs X version. Further are both CVT transmission and have the same number of gears?
    Moreover, are the parts easily available. What about the oil filter, air filter, battery, brake fluid, gear oil & etc. source of buying these basic stuff.
    Some of you might find these question kiddish, but honestly this is the first time i am buying a Japanese car and i dont know jack about it.
  3. #22
    shazz_leo's Avatar
    Oct 2016
    Further, are the parts easily available. What about the oil filter, air filter, battery, brake fluid, gear oil & etc. source of buying these basic stuuf.
    Some of you might find these question stupid, but honestly this is the first time i am buying a Japanese car and i dont know jack about it.
  4. #23
    m.zaman.ali's Avatar
    Aug 2015
    227
    Quote Originally Posted by shazz_leo View Post
    L is Basic while X has some more cosmetic features. All versions (D, L, X, G) have same engine and have CVT transmission.
    All basic maintenance parts like Plugs, brake pads, Mobil oil, oil filter and Air filter, are easily available, rest parts are also available from old spare parts market like Bilal Ganj, Lahore, Sheer Shah Karachi etc
    Sent from my H30-U10 using Tapatalk
  5. #24
    shazz_leo's Avatar
    Oct 2016
    Quote Originally Posted by m.zaman.ali View Post
    Thank you for your response. Further, are all Mira E models eco idle?
  6. #25
    Aug 2015
    227
    Yes, all Mira es are eco idle
Tags for this Thread
