Results 1 to 7 of 7
Thread: Cuore inner cv joint repeated noise
    driver_guy's Avatar
    Jan 2007
    37
    219
    Default Cuore inner cv joint repeated noise
    Cuore 06, passenger side inner cv joint starts clunking within a year after replacement.
    Car has been owned for more than past 8 years.
    This problem was not there untill 2012 when its left and right outer CV joints were changed.
    After a few months of that the inner cv joint started making noise and also there was steering shake above 80kmph
    Wheels replaced and balanced, steering rack serviced, front shocks changed but the steering wobble does not go away.
    Left inner cv joint replaced twice with original NKN in past three years. Clunking goes away but returns after about one year.
    Could this indicate a bent axle shaft or something with the transmission bearing?
    How can the problem be isolated?
    driver_guy's Avatar
    Jan 2007
    37
    219
    Bump ...
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Did you check engine mounts? Spacer in suspension?
    driver_guy's Avatar
    Jan 2007
    37
    219
    Quote Originally Posted by saboor73 View Post
    Gear side mount was changed two years ago. Other mount is fine as per mechanic. But he just inspected visually and did not try to pry up anything
    Is there any proper way to check the mounta
    Also no spacer in suspension
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by driver_guy View Post
    Ask someone to help you open hood of car tell your helper to sit inside the car ask him put car in gear and play with clutch and break (leave clutch and press it the idea is to make engine apply torque without moving car) if the engine moves more than 4 inch than mount are bad
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    what grease is being used in the joints?
    driver_guy's Avatar
    Jan 2007
    37
    219
    Grease used was nkn original tube which came with the joint
