Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By saboor73
  • 1 Post By aa78
Thread: Mira ES concerns and Questions
    ranausmans's Avatar
    Apr 2011
    20
    Default Mira ES concerns and Questions
    Hi Everyone,
    I just bought a 2012 model Mira ES. I have thoroughly read the ES fan club thread and other threads but I still have a couple of questions and concerns. I would be much thankful if somebody can help me.
    1. It has Eco Idle which seems to be working but I don't use it much because I think it's not going to make any difference with mileage. Does Eco Idle do something more than just idling and starting car at dead stops?
    2. It is currently giving low mileage, far more lower than my expectations, it is giving 13km/L. My drive is in small patches, usually 6-7 kms a day and in small patches.
    3. It has blue meter with two small screens, one on left and one on right. What does the meter at left shows? it has things such as 22mL.
    4. It comes with a navigation that has an SD card, now is there any way we can tamper the sd card to change the language? I have thoroughly searched the sdcard for any file such as loading.kwi but it doesn't have. It has eclipse software, I have been searching if I can find an eclipse setup of Sd card, European or American but failed.
    I have read somebody saying that Eco idle only saves 1 mL in 10 seconds, what does this means?
    My biggest concern right now is Mileage.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    1)it just shuts down engine when you stop
    2)getting 13km/l welcome to the reality that how much these 660cc do
    aa78's Avatar
    Dec 2011
    699
    10 Post(s)
    Many here and otherwise mistakenly equate engine capacity with mileage. That is only valid up to certain extent.
    The lower engine capacity means that while bearing similar weight (passenger, luggage, etc) the lower capacity engine will have to work harder to maintain speed and in start/stop conditions and thus any high fuel mileage obtained under specific favorable conditions will vaporize. On the other hand, a higher CC engine with similar loading will have to work less hard thereby giving better mileage.
    Driving style/aggressiveness and keeping RPMs in the sweet spot also matter a lot.
    Did you change oils and other fluids after your purchase?
    ranausmans's Avatar
    Apr 2011
    20
    yes, I did change the oil and air filter. it appeared by seeing the oil and air filter that it wasn't changed since ages.
    zulayed's Avatar
    Sep 2013
    180
    1. it just shuts the engine down when u stop the car to save fuel while idling.
    2. use 0w20 oil or zic 5w20. put in high octane fully or partially when refueling. keep tyre pressure at 34 or 32 for better comfort.(38 is recommended). get the throttle body cleaned.
    3. the 22ml is the amount of petrol u have saved while the engine was off due to eco idling. the screen also shows range, temp and other useless stuff.
    4.i don't think the language of these Japanese players can be changed.
