Results 1 to 19 of 19
Like Tree7Likes
  • 1 Post By hamza_xeg
  • 1 Post By SER_GTR
  • 2 Post By Xulfiqar
  • 1 Post By Xulfiqar
Thread: Mira 2011 CVT - Left Indicator Light is continuously blinking as i turned on the car
    tab001's Avatar
    Nov 2014
    53
    Exclamation Mira 2011 CVT - Left Indicator Light is continuously blinking as i turned on the car
    Assalaam o Alaikoom
    I m here with a problem that my friend's car "Daihatsu Mira 2011 - CVT" left indicator light is continuously blinking as he turned on the car. Mechanics checked the indicator assembly and hazard light assembly but found no fault in these assemblies. Mechanics told me that the car's fuse box (behind dashboard) has issue and flasher is builtin in this model so the whole fuse box needs to be changed.
    I need to know that
    1. What are the possible causes of this issue ?
    2. where is flasher in this model of Mira ? Is Flasher builtin in this model or it a separate component ?
    3. Should I change the whole fuse box (behind dashboard) ?
    Experts (@Xulfiqar @SER_GTR @syncview @capsat)
    Please need help from you guys.
    Thanks In Advance.
    tab001's Avatar
    Nov 2014
    53
    @Xulfiqar Sir
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Did You Install Any Security System In Car...Key-less Entry ETC??? Anything Else Aftermarket Installed???
    It Keeps On Blinking When You Start Car And Turns Off When Engine Is Shut Down? Or Car Is Locked? Or Its Keep On Blinking?
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by SER_GTR View Post
    No, no such type of any system is installed.
    It keeps blinking when ignition is turned on. when switched off the ignition blinking is stop.
    KeiWorks12's Avatar
    Mar 2012
    1,298
    13
    94 Post(s)
    Quote Originally Posted by tab001 View Post
    Maybe the contacts in the Headlight/indicator switch got stuck on left side. Check the switch also
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    changing the whole fuse box is the most absurd solution i heard
    usually its some sort of short circuit or indicator assembly issue
    who is the brilliant electrician working on ur car?which city u from
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,788
    94 Post(s)
    8 Thread(s)
    Certainly there is no need to change the whole fuse box. Maybe some issue in wiring.
    The men are back. @TGT.
    chinyoti's Avatar
    Sep 2005
    27
    11,956
    5
    107 Post(s)
    5 Thread(s)
    Try to find out indicator fuses remove them and start the car. For once remove and refit all indicator bulbs of the left side.
    Is the hazard button functioning okay?
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Do You Hear Blinker Near Fuse Box....You Can Locate It And Check It
    I Dont Think Changing Fuse Box Is The Solution...The WHole Damn Thing Just Can't Control One Blinker ...Looks Like A Short Contact To Me....!Either From Assembly Inside Or Somewhere In Blinker Wiring...You Need To Find Some Intelligent Car Electrician To Check It For You....
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    firstly make sure that this is actually a flasher etc issue, by the looks of it, it looks like a body control module - you will need to connect some scan tool that can check lower level codes, codes from this will show up with the B or C prefix.
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by hash4u View Post
    Did not find any brilliant electrician yet..... From karachi
  12. #12
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by chinyoti View Post
    yess hazard button working ok. we have tried all these u mentioned abv. but have no luck
  13. #13
    tab001's Avatar
    Nov 2014
    53
    Actual issue may be wiring but did not find where is this wiring...
  14. #14
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by KeiWorks12 View Post
    Checked all assemblies but no luck
  15. #15
    tab001's Avatar
    Nov 2014
    53
    We have checked using OBD scan device [image attached] but found no code.
  16. #16
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    This Is Nothing To Do With OBD-II Scanner....Its Not Engine Related Issue
    You Need To Trace Wiring And Find Issue There For Any Short In Wiring...Malfunction Of Blinker Flasher
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    This unit will not show anything other than Pxxxx codes, P = powertrain which are engine and transmission.
    you need a deep level scanner which can interrogate the body control module, ABS etc.
  18. #18
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,788
    94 Post(s)
    8 Thread(s)
    From where can we access such tool ?
  19. #19
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by hamza_xeg View Post
    A decent shop, such tools are very expensive
  20. 01-11-2016, 11:50 AM
    Site Banned
    Reason
    spam
  21. 01-11-2016, 11:51 AM
    Site Banned
    Reason
    spam
Tags for this Thread
