Results 1 to 19 of 19
Like Tree10Likes
  • 3 Post By travelling001
  • 1 Post By IsbCap
  • 1 Post By travelling001
  • 1 Post By umarkhan1
  • 1 Post By ch.talal
  • 2 Post By Ehsan4808
  • 1 Post By huzaifa.haroon
Thread: Mira EiS RPM Calibration?
    AwaisGhouri's Avatar
    May 2013
    38
    92
    2 Post(s)
    Default Mira EiS RPM Calibration?
    i have mira eis
    it was working perfectly with milage of 30.7 km/ltr
    but few days ago i felt that tunning needed so went to workshop three days before
    changed plugs and clean throttle body with cleaner spray
    now rpm is very high
    no one was able to reset or calibrate the rpm
    went to very known 4 machanics with scanner, they used three types of scanners but failed to calibrate rpm
    now milage is 13.5km
    is there anyone having same experience ???
    Grey hairs sign of Age not Wisdom
    travelling001's Avatar
    Mar 2015
    Why does everyone have to touch a car that is working perfectly? And the other thing is, why do you take your car to a mechanic when they have absolutely NO IDEA how to work on this model, which means they have no service manual? I am sure it is either two things.
    When he worked on your throttle body, he either 1.) Did NOT replace the throttle body gasket that goes behind it OR he did not bother to put it back in, if he removed the throttle body, and now there is a vacuum leak that is causing the ECU to compensate the air/fuel mixture by raising the RPM's. If he did NOT remove the throttle body, then he used a cleaner spray, such as carburetor cleaner, that might have affected/damaged oxygen sensors, catalytic converters and other sensitive sensors.
    2.) When he was removing the throttle body, he has disconnected some vacuum hoses or other emission related hoses and forgot to put them back on. You should check to see if anything has been removed or missing and check again.
    Also, why did you have your spark plugs changed? The original spark plugs will last for 130,000 kms before the first replacement is needed. They were NGK Iridium Tipped and in Japan, one spark plug is around Rs. 4,000.
    See if the things I mentioned help you out and then let us know if you have sorted it out.
    May 2013
    38
    92
    2 Post(s)
    no he did'nt remove throtle body
    he just sprayed that cleaner
    and asked me to get new plugs, and i purchased three plugs @3000rs
    and he kept my old ones
    and another mechanic told me that throtle bodys is damaged u have to get a new one
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    How easy it is for those stupids to ask for throttle body replacement...!!!
    First try to get the original plugs back and reinstall them to see if problem gets fixed.
    If all sensor connectors are intact, and putting the original plugs back doesn't resolve, then the problem is most likely with IACV.
    And also make sure the car is getting to operating temperature normally or not?
    Mar 2015
    Actually, first of all, your car does not have a IACV (Idle air control valve). The ECU adjusts idle speed depending on engine load.
    You should definitely have your ORIGINAL spark plugs fitted back if possible. Is your car still running at High rpms at idle?
    If it is still running High RPMs at idle, it may be just the gasket that has been damaged. Did you check the emissions hoses or any other vacuum hose that may have been disconnect?
    If you are interested in a fix, please private message me. I can give you another solution, if you are in Lahore.
    May 2013
    38
    92
    2 Post(s)
    thx for answers
    yes i m in lahore
    yes i got those plugs back again from that machanic
    rpm is a very long story
    let me cut it short
    i went to a very genius and honest man's workshop (advised by my friend) his name is fahad
    in johar town
    he did a totka with my car, he has solved this problem b4 many times
    and that totka fixed rpm absolutely
    but my average is still not satisfactory as once it was
    new plugs were installed by previous mechanic were came out very rusty
    i dont know why
    then i asked fahad to install my previous plugs he cleaned those plugs very breifly,
    after that i took a drive, average quickly jumps to 27km/L
    and after one hour average is again back at 14km/L
    this is really confusing me
    i m gonna sell this car
    Mar 2015
    That is great your got the RPM fixed. Can I ask, what exactly did he "fix" or do to fix the high RPM issue at idle?
    If you let me know what EXACTLY he did to fix it, then I might know why your average is so poor for the moment. It is a simple fix.
    Just tell me exactly what he did to fix the problem, and I can advise on what you can do.
    May 2013
    38
    92
    2 Post(s)
    well dear thats his buisness secret
    and should'nt share here
    inbox me ur cell number i will tell u what he did
    kamranzafar781's Avatar
    Oct 2013
    Rawalpindi
    38
    300
    7 Post(s)
    Quote Originally Posted by AwaisGhouri View Post
    Awais Bhai yahain par share kar dou so that all can benefit from such workaround.
    May 2013
    38
    92
    2 Post(s)
    nai bhai
    its cheating with him
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,312
    6
    8
    51 Post(s)
    4 Thread(s)
    nai bhai
    Lol it must be a million dollar secret then.
    Keep it with you brother warna toyota prius ki sale band ho jae gi...
    Keep it up (Y)
    Just Do It Your Self!!!!!
  12. #12
    huzaifa.haroon's Avatar
    Aug 2012
    5,002
    10
    225 Post(s)
    7 Thread(s)
    thx for answers
    yes i m in lahore
    let me cut it short
    in johar town
    i dont know why
    Don't expect miracles. 27 is really impossible to achieve within city
    Sent from my ALE-L21 using Tapatalk
    Always respect your parents
  13. #13
    May 2013
    38
    92
    2 Post(s)
    Quote Originally Posted by huzaifa.haroon View Post
    then whats this
  14. #14
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Well Carb cleaner tends to swell the rubber and when he sprayed two things can happen. Either the spray caused some gasket to de form OR as i have seen many times after throttle cleaning the throttle plate develops gap which is due to wear. Cleaning allows gunk to go away leaving vac leak.
    Let us know your fuel trim Short term and long term and we will see whats up with the fuel consumption.
    93 Accord CB7 (Sold) / 2005 CL7
  15. #15
    ch.talal's Avatar
    Mar 2014
    663
    19 Post(s)
    Never spray these stupid carb cleaners in throttles in EFI cars. These make the situation worst instead of doing any good and performance improvements. Besides never get such stupid tunings done in modern cars. These don't need such tunings.
  16. #16
    Ehsan4808's Avatar
    Sep 2007
    34
    1,811
    7
    53 Post(s)
    @AwaisGhouri
    First of all, the car you own is Mira ES.. Not E I S..
    I also have a Mira es.. The RPM comes back after driving for a while. like 4 - 5 days.. The ECU just adopts your driving style and learns.. I have gone through this.. Few Mira ES owners called me and asked about the same issue, my reply was only to drive the car for 4 - 5 days and it the idle RPM would settle down itself.. And yes it worked for them too.
  17. #17
    Aug 2012
    5,002
    10
    225 Post(s)
    7 Thread(s)
    then whats this
    Bhai sahab, after you refill you get this kind of average for a short period of times. Thorra chalne do phir dekhna
  18. #18
    Aug 2012
    5,002
    10
    225 Post(s)
    7 Thread(s)
    I can show you average of 99km/l too but that would be very unrealistic
  19. #19
    May 2013
    38
    92
    2 Post(s)
    thx huzaifa
