Results 1 to 3 of 3
Thread: Cuore AC compressor problem
    Newbie Follow
    khizz's Avatar
    Mar 2008
    Wah cantt
    32
    Default Cuore AC compressor problem
    I have a Cuore 2007 and it's AC isn't working really well. It Just gives mediocre cooling. I'm thinking about changing the compressor.
    Plz gimme advice about which compressor to go for. Duet....success...or some other kabli compressor???
    Also i want to know if i can get a used compressor of any imported car in pindi. Will it fit in the local cuore???
    ahmed2396's Avatar
    Dec 2011
    36
    2,330
    5
    55 Post(s)
    7
    You should check refrigerant pressures both low side and high side. Ensure drier and evaporator are good, get a complete service.
    Your ego is writing cheques, your body can't cash.
    Atif_Jawaid's Avatar
    Aug 2012
    129
    please don't go for big compressor for for ur little anjel ...
    it put load on engine ....
    chk the line of A/C evaporator and gas ...
