Results 1 to 9 of 9
Thread: Knocking Sound after Transmission fluid change
    ahmad88997's Avatar
    Mar 2015
    Default Knocking Sound after Transmission fluid change
    I just changed my Cars Transmission Fluid ATF-KIXXX Mira 2009. After this my car started to shift bit earlier and at constant speed i feel knocking sound from engine. sound is like when petrol quality is poor but i tried High-Octane, but still knocking sound is coming On Constant speed, not just when car shifts.
    I need Help to work this out. Tell me if my car needs any Computerized Tuning or anything.
    Thanks.
    hash4u's Avatar
    May 2005
    38
    24,381
    18
    406 Post(s)
    13 Thread(s)
    13
    i hope u did not pour in non cvt ATF in a CVT box
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    2009 Mira it should be CVT you should have poured toyota cvt-f
    ahmad88997's Avatar
    Mar 2015
    Mira 2009 Straight Gear Box is ATF Not CVT
    suneelmunj's Avatar
    Jan 2006
    37
    3,091
    8
    41 Post(s)
    4 Thread(s)
    I guess you have put in wrong grade of gear oil plz chk it and get it chnaged asap .. plus check gear oil cooler is working fine it could also cause knocking
    Allah say hi sab hota hai BAY SHAK
    waqt say pehlay nahi
    naseeb say zayada nahi
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    490 Post(s)
    19 Thread(s)
    It Can Just Be Your Gearbox Part Failure Causing This Sound Or A Wrong ATF Leading To This
    Make 100% Sure You Used Correct Fluid ...!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    ahmad88997's Avatar
    Mar 2015
    100% bro i pour the correct fluid
    blueazure's Avatar
    Jan 2012
    385
    9 Post(s)
    did you read the manual ?
    what does the gear say, P R N D S B OR P R N D 2 L ?
    ND2L needs ATF Dexron III, use ZIC, quantity is 3L .
    the other one needs CVT
    whiteangel's Avatar
    Nov 2005
    2,243
    9
    65 Post(s)
    He says he can feel the gear shifts, so its definitely not a CVT.
    Never argue with an idiot, they drag you down to their level and beat you with experience.
Tags for this Thread
