Results 1 to 12 of 12
Thread: Mira ES 2013 Hard Steering
    sdanish00's Avatar
    Feb 2014
    Rawalpindi
    Default Mira ES 2013 Hard Steering
    I recently bought a Mira ES 2013, 16000 km driven, the problem is that its steering is very hard. I have tried and driven another mira and there is significant difference between the two, mine is very stiff. The car is like brand new, no major accidents. + i have also tested for any errors using the OBD device but there are no errors. Can anyone help me with this?
    Rustle's Avatar
    Jun 2012
    522
    22 Post(s)
    Quote Originally Posted by sdanish00 View Post
    My mira's steering was hard as well but later it got soft.. Use steering cover tooo...
    pistonhead's Avatar
    Dec 2009
    86
    1,445
    24 Post(s)
    Solution
    Community Votes: 1
    Steering cover does not make the steering soft. Go have it checked from a mechanic - my Mira has a really soft steering.
    Quis custodiet ipsos custodes?
    the.real.stig's Avatar
    Mar 2014
    Multan
    33
    I have driven a friend's mira es 2012 many times and its steering is really soft. I am quite sure it has an EPS in it. Get yours checked asap.
    Sent using two cans and some strings.
    Rustle's Avatar
    Jun 2012
    522
    22 Post(s)
    I am telling u it will get soft with the passage of time!
    sdanish00's Avatar
    Feb 2014
    Rawalpindi
    after how many kilometers drive did it get soft?
    sdanish00's Avatar
    Feb 2014
    Rawalpindi
    Quote Originally Posted by pistonhead View Post
    Can u suggest a good mechanic, because its my first time with an EPS system...
    mwm749's Avatar
    Mar 2008
    Dubai
    59
    1,160
    29 Post(s)
    Community Votes: 2
    @sdanish; EPS (electronic power steering) motor is not working which provides assistance while turning. You say your car is non-accidental so you should start by checking the fuses in the fuse box. Hopefully you will find a blown fuse.
    Replace it with a new one and the problem should be solved.
    However if it burns out again then you need to take your car to a good electrician.
    I Dont Drive Fast, I Fly Slowly....
    Rustle's Avatar
    Jun 2012
    522
    22 Post(s)
    It got soft after 25k
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Dear a normal practice of dealers here. They send imported cars to khradia and get their ends pressed. So probably this can be the case. You hve to be very very careful messing with this car. If there is no check light for eps then the problem can b in the steering assy.
    Sent from my SM-G900H using PW Forums mobile app
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    EPS is realy soft and one should not feel any stifness. I will suggest you visit a good machanic and ask him to unbolt the ends and check the ball joints and tie road ends.
  12. #12
    m.zaman.ali's Avatar
    Aug 2015
    227
    Quote Originally Posted by Rustle View Post
    Lolzzzz.
    Mira has electronic steering which is really not simple Mechanical that will be soft with the passage of time
    Sent from my H30-U10 using Tapatalk
