Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Mirza967
Thread: why my mira engine vibrates on Ac
    gemini786's Avatar
    Oct 2010
    84
    7
    Default why my mira engine vibrates on Ac
    having problem in my mira 2006 model
    its perfectly running good Alhumdolilah but there is a problem whenever i stop the car on signals or anywhere in "D" mode but foot on breaks its engine keeps vibrating and when i turn off the Ac it becomes normal with no vibration,it vibrates in "P" mode as wellbut less then "D" mode with AC on.
    whats the issue? does it require the tuning? but who does such tuning? plz help me as Mechanics tu boohut lootely hane ...masla kuch hota hey batatey kuch orr hane.... plz help thanks all
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    Quote Originally Posted by gemini786 View Post
    check engine mounts......
    whiteangel's Avatar
    Nov 2005
    2,240
    9
    65 Post(s)
    Community Votes: 1
    Seems like an idling problem. The idle speed should increase slightly with the AC on. If it is not increasing to compensate for the increased load, then you might have a blockage in the Idle air control valve (located on the throttle body). Opening it up and cleaning it usually solves the issue.
    Never argue with an idiot, they drag you down to their level and beat you with experience.
    gemini786's Avatar
    Oct 2010
    84
    7
    thanks for ur reply bro,,, who can solve this issue AC waly or machanic ?
    gemini786's Avatar
    Oct 2010
    84
    7
    whats engine mount bro???
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,308
    6
    8
    51 Post(s)
    4 Thread(s)
    Foundation/foteeshan for local mechanics
    Just Do It Your Self!!!!!
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    1st u check foundations i.e mount then go for any technical work because mechanics may ruin it if they do thraaattttllle baady servise.
    gemini786's Avatar
    Oct 2010
    84
    7
    Default great
    Quote Originally Posted by Mirza967 View Post
    thanks soo much jazakALLAH everyone for very useful info...
    whiteangel's Avatar
    Nov 2005
    2,240
    9
    65 Post(s)
    This is definitely not an engine mount problem. If it was, you would feel it even with the the AC off.
    chusmankhalid's Avatar
    Aug 2014
    Gujranwala
    260
    6 Post(s)
    my Alto's 660 when with A.C knocks on low speeds and tends to shut down with a jerk. without A.C its all perfect. Issue ?
