Results 1 to 5 of 5
Thread: Coure vibration
    umar6633's Avatar
    Jul 2015
    Default Coure vibration
    Coure rhythmic vibration in the morning at start, upon reversing switches off in the morning, need to give it race to prevent it from switching off. Vibration in gear, lesser vibration in neutral. New engine mounts, new spark plugs, recently tuned, 6 month old battery. Don't know what to make of it. Can't tell if it's electrical or mechanical. I have a hunch but prefer expert advice, all my ideas haven't worked out as mentioned above.
    ammadd's Avatar
    Mar 2015
    Rawalpindi
    405
    Fuel Pump/ Fuel Filter my guess
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Solution
    Quote Originally Posted by umar6633 View Post
    I think rpm too low. auto choke is turned off? have you got plug wires checked? how old is car? when was last tuning done?
    umar6633's Avatar
    Jul 2015
    2008 coure. Tuning done last month, carburettor packing changed, spark plug cleaning. There is no rpm meter, Yes it maybe low rpm. Will check if auto choke is off. No plug wires have not been checked. Your suggestions are right, I will follow up on them, auto choke and wiring. As battery is new, alternator is working well, tuning was done.
    It's rhythmic vibration, it comes waves in gear and neutral, and starting in morning.
    Thanks.
    nauman1000's Avatar
    Apr 2009
    Peshawar
    32
    49
    Ignition timing & ignition related issue
