Results 1 to 12 of 12
Thread: mira manual 2008 engine oil burns, knocking
    taj0333's Avatar
    Feb 2012
    Default mira manual 2008 engine oil burns, knocking
    Hello everyone. Please guide me as i am having trouble in diagnosing the real problem of car as different mechanics are misguiding.
    I have mira manual 2008 model which was running perfectly with only 1 issue of oil level which is reduced 1 liter after 2000 km. But i filed it once and change it after 3000 km.
    Now for the past couple of weeks car pick gone low on height. Generates heat on small travelling, knocking with high acceleration, generates lots of smoke when accelerating, now engine oil of 1 liter burned in 4 days.
    Water level is full.
    What will be the reason?best Mechanic in rwp/isb?
    Thank you
    taj0333's Avatar
    Feb 2012
    Engine oil used zic 20-50. Car odo 125k.
    pistonhead's Avatar
    Dec 2009
    86
    1,439
    24 Post(s)
    Your engine is burning oil, you are already using a heavy oil. I am afraid the only option is either an engine rebuild or a replacement engine
    Quis custodiet ipsos custodes?
    taj0333's Avatar
    Feb 2012
    :-( any good mechanic in isb rwp?
    MotorHead77's Avatar
    Aug 2013
    52
    I'm having the same problem my car is mira custom auto.....if you find a good mechanic in twin Cities.....plz let me know as well....thanks
    Sent from my SM-G920T using PW Forums mobile app
    Getting "High" is my Job
    Aug 2013
    52
    Most likely you will have to swap the engine as rebuilding the engine is not very successful by the local ustaads
    Aug 2013
    52
    Stay in touch
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    my mira was decreasing oil eversince i bought it from karachi as a first buyer but i waited for a year and changed rings last year from Multan. the ring job was successful however, i noticed an engine leak. the leak started increasing in volume and was primarily from the head area probably from gasket. got the head gasket replaced from Yazdani motors karachi but the leak persisted although it decreased in volume. Couple of months back on moving to Rwp got some silicone on the same old gasket from sultan da khu and voila today the engine is leak free. But yes the locals khwar you a lot.
    Al-Khalid,(6TD2, 1200 hp): In line horizontally opposed, 6 cylinders 12 pistons, 2 stroke liquid cooled multi-fuel engine with turbo super charger and indirect fuel injection
    m.aasiff81's Avatar
    Oct 2016
    Quote Originally Posted by homayoon View Post
    have you got solution, I am facing same problem , I dont know what is best either change engine or rebuild? have you found any good shop for engines?
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    Quote Originally Posted by m.aasiff81 View Post
    what is your location?
    i personally believe that rebuilding the engine / ring job is an easy job for a good mechanic in pakistan but where to find a reliable mechanic? if in Rwp / isb go to rizwan bhai in sultan da khu, i believe he is an expert. In karachi i would suggest yazdani motors, they are expensive but can be fairly reliable.....
    m.aasiff81's Avatar
    Oct 2016
    Dear Homayoon,
    I lives in Lahore. everybody is telling me to buy new engine but I am considering to keep using as long as it fail completely.
    please give your opinion.
    Regards,
  12. #12
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    if you can get a good engine upto30 k, i believe that would not be a bad option.
Tags for this Thread
