Results 1 to 11 of 11
Thread: Daihatsu mira suspension
    osamamajid73's Avatar
    Aug 2016
    6
    Default Daihatsu mira suspension
    Is the mira being low on ground is really a issue or i have just heard the rumors?
    Recently my friend's cousin has bought mira 2012 model and it sucks on bumps in karachi (according to him). To such extreme that the pillar got damaged. So is this issue of mira in Pakistan?
    Experts?
    varietyautomobiles's Avatar
    Apr 2016
    46
    Aslamoalaykum, Dear don't worry , First of all you need to check your Shock Absorbers. I hope you get rid of that problem, InShaAllah
    Aug 2016
    6
    Quote Originally Posted by varietyautomobiles View Post
    shayad ap meri baat smjhy nhi mein ye khe rha hun k imported mira jo hai uski ground clearance boht kam hai tou waqi kam hai hai ya sirf rumor hai?
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    the ground clearance of miras is generally low as with almost all Japanese cars. I have put metal spacers under my cars springs and the car is now trouble free. Obviously the manufacturer has designed the car without these spacers and therefore there is some loss of stability at high speeds above 90 kmph in my opinion. However, i have driven it recently between Isb to Peshawar at 135 kmph as well on the Motorway without any considerable feel of instability. you in any case wont be driving that fast in karachi. You need to make sure that the spacers you get are not too high otherwise you will have to contend with a dug-dug sound on the bumps with more instability. This was the case with me so i got the spacer size reduced from the Kharadia later and now the car is perfect.
    Al-Khalid,(6TD2, 1200 hp): In line horizontally opposed, 6 cylinders 12 pistons, 2 stroke liquid cooled multi-fuel engine with turbo super charger and indirect fuel injection
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    The car is 2008 mira
    Aug 2016
    6
    Size and cost?
    m.zaman.ali's Avatar
    Aug 2015
    227
    Quote Originally Posted by osamamajid73 View Post
    Experts?
    Yes, this is the issue, But problem is these stupidly build speed Breakers not suspension. Mira will easily cross any speed breaker with full load if that speed breakers is Built as per international standard height & width.
    Most speed breakers in Pakistan are actually car breakers :-)
    Sent from my H30-U10 using Tapatalk
    Aug 2015
    227
    Quote Originally Posted by homayoon View Post
    Which size you are using now?
    Half inch or....?
    Aug 2016
    6
    Seriously means no rules no regulation. Speed breakers are like to make the car fly.
    homayoon's Avatar
    May 2011
    41
    418
    6 Post(s)
    i am using almost .75 inch spacers, if i correctly recall. However, one can first have a feel with a big spacer and the same can later be reduced by the kharadia. Cost would around a 1000 bucks incl mazdoori....
    DrUsmanNawaz's Avatar
    Jul 2011
    Wah cantt
    34
    3,925
    18
    165 Post(s)
    2 Thread(s)
    Almost all JDMs have low ground clearance... if your family is small, drive carefully and very slowly over speed breakers... if family members are more, u can use spacers...
    Experts?
    Keep Faith in Allah...
