Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 67
Thread: zic A+ 5-30 synthetic oil in cuore
    imrandahar's Avatar
    Jun 2005
    Sadiqabad
    34
    1,174
    2 Post(s)
    Default zic A+ 5-30 synthetic oil in cuore
    im using zic a 10-40 oil in my cuore eco, can v use zic A+ synthetic 5-30 engine oil in summer?
    ikd
  2. #21
    saadisb's Avatar
    Aug 2006
    28
    2,684
    3 Post(s)
    ^^i agree.
    and scheme is for member ship card holders. *was* :-(
    How to Modify Your car: Put some fiberglass crappy looking bumpers, spoilers are essential for your daily driver, and don't forget the TypeR.
  3. #22
    imrandahar's Avatar
    Jun 2005
    Sadiqabad
    34
    1,174
    2 Post(s)
    im using zic a n change it after 5000km in cuore
    ikd
  4. #23
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    As discussed before, both A and A+ are "Synthetic Formula" and not actually Synthetic oils !
    Doesnt matter if you use it in a coure, you can switch to any engine oil until and unless you car's engine is old and weak.
    Coure Mehran other small cars having small engines, make oil loose its viscosity earlier, Zics dont loose viscosity early, so better switch to any Zic having 40 as its upper limit. I think Zic's Hiflo is most suitable in Pakistani conditions.
  5. #24
    civic_2002's Avatar
    Aug 2008
    35
    120
    !c123pk
    bhai there is no differnce in "synthetic oil " or "synthetic formula"
    u may have seen caltex formula or castrol formula/ new formula
    these small things which illiterate pupil or less educated pupil make it foucus like that & try to make other fool but educated pupil shouldnot catch by them by these small terminologies
    small engine/cars coure/mehran or bigger cars doesnot have any sense or connection with making oil viscosity earlier . engine capacity has nothing to do with this
    zinc or any oil doesnot guaramtee that they will not loose viscosity earlier
    Warning: I am here to educate pupil, to create sense, to discuss logics, to give research, to increase literacy
    Beware!!! Dont come here for time passing or enjoyment,I will make you educated & mannered
  6. #25
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    "Synthetic Oil" and "Synthetic Formula" are 2 different things, if you want the real Synthetic oil, you ll have to pay around 2500 instead of 1100 rupees, then you ll get yourself a good Synthetic Zic XQ
  7. #26
    HumanGenius's Avatar
    Mar 2007
    22
    4,547
    Would you recommend Zic XQ for Civics/Corollas/Accords?
    What good is a Genius without the Human aspect?
  8. #27
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    For smaller engines loosing their virginity i mean oil's viscosity, thats a proven fact, my little experience also suggest the same.
    Smaller engines=Higher RPMs=Oil life shorter.
    Bigger engines=Lower RPMs=Oil life Longer.
    I assure you, use the same oil for a Mehran / Coure and other bigger 1300 / 1500 / 1800 cc car, you ll see the difference, the oil in mehran / coure will surely need an earlier change
  9. #28
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    @Human Genius, if you have enough $ to waste, then whynot, if you do so, dont change it before 10,000 kms atleast. It can go much more then that, it wont loose its viscosity in any case (synthetic), all you have to check is the dirt in it
  10. #29
    civic_2002's Avatar
    Aug 2008
    35
    120
    @c123pk
    no it is technically 100% wrong
    try to understand bhai, samller enginer has no connection with higher rpm & thus higher rpm cannot make life of oil shorter, u can read nay booklet ,any automobile magaazine, go to any suzuki/honda/toyota dealer, serach on internet
    u will not find this theory
    what is connection of rpm with viscosity???doesnot make sense yaar
    it is completely wrong that oil for a Mehran / Coure and other bigger 1300 / 1500 / 1800 cc car are different
    u may be bitter experience beacuse may be your driven mehran/coure had ruined /ended engine that's why they damage oil or eat oil & so u make this assumption that small engine cause earlier oil change
    but take mehran & corolla with new & fine engine & test urself
  11. #30
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    Yaar, if thats the case, i ll change my spectra, daewoo, Joy and mehran's oil @ same milage, the reality is spectra and daewoo need oil change @ 5,000 and on the other hand the same brand's same oil becomes water @ 3,000 kms in mehran and Joy @ 4,000.
  12. #31
    Mar 2007
    22
    4,547
    okay, but that means this is WAY cheaper!
    Change at 10,000km and PKR 3000 for 4L (est) Xq
    Change at 3,300km and PKR 1500 for 4L (est) Mineral oil
    Means at 10,000km, you pay 3k one way and 4500rs the other. Its cheaper, Im going for it
  13. #32
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    406 Post(s)
    13 Thread(s)
    13
    @c123pk
    logical talk making sense (Y)
  14. #33
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    And remember change it only when you feel its dirty (let the mechanic check it for you) else use it for 12 - 13k kms atleast, Nothing bad in using it more, original Synthetic oil Never looses its chiknahat
  15. #34
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    Hash4u, thanks man, most of the things i have learnt here are from people like you @ pakwheels
  16. #35
    hash4u's Avatar
    May 2005
    38
    24,377
    18
    406 Post(s)
    13 Thread(s)
    13
    bhai kion sharminda kar rahay hain thank u
    two more tips from my side.....
    engines with very high mileage getting weak (mineral is better)
    High mileage engines(oil change cycle should be frequent)
    and guys if its a cuore it doesnt mean it doesnt need a good oil or can run on cooking oil
  17. #36
    Mar 2007
    22
    4,547
    What is chiknahat...?
  18. #37
    saadisb's Avatar
    Aug 2006
    28
    2,684
    3 Post(s)
    its viscosity.
    @c23pk
    do u know how to use oil checking kit? i have got one used in ships.
  19. #38
    imrandahar's Avatar
    Jun 2005
    Sadiqabad
    34
    1,174
    2 Post(s)
    what is oil checking kit? plz explain?
    ikd
  20. #39
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    @imranisb, no dude, i havent used a oil checking kit, must be 1 hell of a gadget !
  21. #40
    saadisb's Avatar
    Aug 2006
    28
    2,684
    3 Post(s)
    no its very simple one. i will look for its pics.
