Results 1 to 4 of 4
Thread: Problem with Cuore A/C
    afz411's Avatar
    Feb 2009
    24
    15
    Default Problem with Cuore A/C
    HI Guyz.. I hav a Cuore CX Automatic 2007.....I hav Cng installed in my car... Previously my Car's A/C would stop working whenever i removed My foot from the accelerator..if I would continue to apply brakes for more than 1 minute..for instance in a traffic Jam..The compressor would stop working... I took my car to The mechanic..he fixed the problem saying that there was sumthing wrong in the CNG setting.. But now i m facing another Prob...as soonn as the Temperature Gauge Reaches the mid Point..Or in other words its normal position the Compressor would stop working...as the Temp Goes down the A/c starts working again...I got my A/C serviced nd got the radiator serviced too...But the problem continues.. Any suggestions would be appriciated...Looking forward for ur help...
    afz411's Avatar
    Feb 2009
    24
    15
    wont Ayone Help..???
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Check the setting of thermostat,I think it needs some adjustment.
    Never loose hope in life,every step gives u something.
    shahidaziz's Avatar
    Oct 2007
    Rawalpindi
    41
    30
    Dear i think that the engine over heat sensor making the a/c tripped this sensor is installed near the water temp sensor with two wires checked it
