Results 1 to 3 of 3
Thread: Aftermarket A/C for Cuore
    hunnyahmed's Avatar
    Dec 2005
    25
    4,367
    3 Post(s)
    Default Aftermarket A/C for Cuore
    Wat is the performance of an Aftermarket A/c on Cuore CL.
    Those who have installed it r u satisfied with it or not?
    hunnyahmed's Avatar
    Dec 2005
    25
    4,367
    3 Post(s)
    no one??
    server4lims's Avatar
    Jan 2009
    Karachi,Lahore
    44
    89
    satisfied with performance on a/c in coure
    i installed "sanden" compressor & result was very good some years ago form karachi
    actually one thing keep in mind that
    F/F A/c
    F/F Cng
    this phenomena is only thinkable here in Pakistan
    nobody cares outside that whether it is F/F or non F/F
    only differnce which i experience it is that in F/F all things are pre installed so very clean installation( sp. in suzukis)if u put from outside, the method they work is not accurate as factory, u can easily understand by seeing that it is F/F or not
    so remember " F/F " is not related to "Performance" but related to fabrication, setting etc.(that's why in Pakistan pupil claim more for F/F)
    but in my experience if it is installed properly then no tension worry but installation must be by Experts, not all roadside pupil can do it
    Drive carefully,someone is waiting for u
