yaar for opening lights don't take risk. If glass is broke while opening by yourself your light will be no use for then. Take the lights to light mechanic he will detach the glass from light. Then after masking you can apply paint and remove the masking and light mechanic will fix the light glass again...
this paint is used for making lights in black smoke. Its called flat black paint.
here is the picture of it.
