some special Tea Break during the work.
coming into shape slowly slowly ...still reinforcemnt remainaining..
Nice projectDo u think it can lift an engine??
thanks .
some special hand crafted mountings for the Shock assy.
some updates as shock(Jack) is tentatively mounted and its multi positioning option is also checked
[ATTACH=CONFIG]1086829[/ATTACH]
best of luck for project,so thats your in house workshop,worth visiting once at least.
very nice and diffrent project.
You've done a great job on the lift! Its a must have when swapping an engine. Now you should get it powdercoated instead of painting it.
Bro the 90 degree rod need some more support from the floor as mentioned in the above pic and its very imp as the whole weight will be bear by this single rod u need some more support......And do check it by lifting more weight than normal or heavy engine which ever u think its gonna lift one day to assure its strength before lifting any engine..Anyhow it just loved ur work such a clean and unique job
As the project is still in its finalization stage but as its about to completion so decided to play with some diffrent engines.
starting from 1.0 litre patrol*
Aamir Bhai you are always welcome to visit .
Thanks and yes it can be done.
