ASAmy car deck and modulator has suddenly stopped working..may b the fuse is the issue, plzguide as i dont see any fuse for the lighter or the deck on the fuse box..
ps lighter port not working as well..
thanks to all in advanceAH
Take out the headunit. At the back, take the wire grip out. Behind the grip you'll see the fuse.
thanks bro il check it and let know..
but im stil unable to understand why the lighter isnt working..there isnt any separate fuse either, does the lighter use the same fuse also??
This particular fuse is only for the headunit. If the headunit and the lighter share a wire and that wire isnt fused, it's possible that the wire might've burnt.
@boththanks alot..@reezvan ok bro poocha ap se..??but the thing is..i didnt use any lighter, this socket is used for modulator purposes and this is a pretty lame device, a heat coil is a heavy thing that might burn the fuse..so i think if the fuse is farigh and i replace it then it should work properly..for the modulator ie..and also bro plz tell me where is the deck/lighter fuse on the fuse box as there is no listed fuse for lighter or radio on the fuse box..
