You will need 1 x 20 ohm 7 watt resistor.
The 20 ohm resistor is color coded: Red, Black, Black, Gold.
Each 20 ohm resistor consumes 6050 milliwatt.
Total power consumed by the resistors is 6050 milliwatt.
Total power consumed by the LEDs is 2090 milliwatt.
Total power consumed by the circuit is 8140 milliwatt.
Total current drawn by the circuit is 550 milliampere.
these calculations are done on basis that foward voltage on led is 3.8 and cuurent 500 mah
