Can anyone tell me that whats the weight of daewoo racer car. i want to buy a hydraulic car jack like these. which one is ok either 2ton or above .thanks.
I would be greatful if anybody could help me in this regard
It must be Around 1100kg.
so is 2 ton enough or should i go for 4 ton
1 ton - 40kg. so calculate ur self bhai.
1Ton=1000KG...
http://www.onlineconversion.com/weight_common.htm
i think 1 ton=1000 kg
bro 2 ton is more than enough...
we use 4-5 ton for jeeps
btw the original daewoo screw jack is pretty ok.. why go hydraulic?
get a good quality hydraulic.. they usually fail when most required
thanks @ Akifbut orignal one is out of order , buying hydraulic cuz it is easy to use as compared to screw jack i guess what you say?
It's around 980Kg - having said that, you cannot and will not lift the entire car (off the ground completely) on one jack.
go for 2ton it enough
Oops.......! messed up the calculation. Sorry Bro. in tension these days.https://www.pakwheels.com/forumreply_az_TopicID!76512~ForumID!31~page!2~pw.html
2 ton jack is enough , i have a 2 ton for my civic
Thanks ALL .
I will go for 2 ton
