Bro if you got good quality Plastic pipe then use it otherwise go for rubber pipe as the pipe of my ride blowed after 2weeks
Bro first off all make a hole in pipe of exact size of Sensor
Then clamp the pipe on throttle tightly and ur there.
Note both Sensor and throtlle must be tight enough so tht no air is going inside from there
https://www.pakwheels.com/forumreply_az_TopicID!76352~ForumID!27~pw.html
