Spy Shots from Autoblog: Photoshop Rendering from Wildspeed:Cabrera Spyder By Evren Milano: More Accurate Rendering from Marco van overbeeke: From the front, it features a completely new fascia and brand new LED headlights which can be clearly seen in these images. It also features larger front air intakes and an even more menacing stance. At the rear, the quad exhaust pipes are apparent as is the brand new taillight and rear grille design. Finally, the Lamborghini Cabrera will feature a completely new engine cover and roof design.Under the hood, the Lamborghini Cabrera will feature a similar 5.2-liter V10 engine as the outgoing Gallardo. However, power is expected to be lifted towards the 600hp mark.Arguably most significantly however, the 2015 Lamborghini Cabrera is expected to feature an all-new seven-speed dual-clutch transmission indicating that Lamborghini has finally succumbed to the pressure and won?t release the Cabrera with a similar ISR transmission to the range-topping Lamborghini Aventador.It?s most likely that the 2015 Lamborghini Cabrera will make its world debut at the Geneva Motor Show 2014 in early March next year. Also as expected, the 2015 Lamborghini Cabrera will likely share many technical features with the upcoming second generation Audi R8 which will hit the market after the Cabrera.
Last 2 picsUfffffff
Sent from my A10 using PW Forums mobile app
If I had a Billion bucks, I would buy it in a blink of an eye & go on a road trip across Europe.
Bhai agar billion bucks agaye to aik mere liye b le Lena plzzzzz
Aur meray liyai bhi please
agar sub key liye aik aik leney lag giya tu bhai petrol kahan sey aaye ga road trip key leye?
