it's bufori and the MKIII is an 06 concept car
2006 Bufori MKIII La Joya
Year 2006
Make Bufori
Model MKIII La Joya
Engine Location Rear
Drive Type Rear Wheel
Traction Control
Body Material Carbon Fibre and Kevlar Body
Weight 1640 kg | 3616.2 lbs
Performance
0-60 mph 7.8 seconds.
Top Speed 200 km/h | 124.3 mph Similar top speeds
Engine [Optional Engines]
Engine Configuration V
Cylinders 6
Engine Electronically managed ignition and fuel injection system
Water-Cooled
Aspiration/Induction Normal
Displacement 2656.00 cc | 162.1 cu in. | 2.7 L.
Valves 24 valves.
4 valves per cylinder.
Horsepower 170.00 BHP (125.1 KW) @ 6000.00 RPM
Torque 25.00 KG-M @ 4000.00 RPM
HP to Weight Ratio 21.3 LB / HP (Vehicles with similar ratio)
HP / Liter 63.0 BHP / Liter
Bore 86.70 mm | 3.4 in.
Stroke 75.00 mm | 3 in.
Compression Ratio 10:1
Fuel Type Gasoline - Petrol
Exhaust Manifold Stainless Steel c/w 3 x Three stage catalytic converters with oxygen sensors
Vehicles with similar horsepower and weight
Gear Ratios
1st Gear 2.842
2nd Gear 1.529
3rd Gear 1
4th Gear 0.712
Standard Transmission
Gears 4
Transmission Sequential
Final Drive 3.77
Dimensions [Optional BodyStyles]
Seating Capacity 2
Exterior
Length 4330.001 mm | 170.5 in.
Width 1807.001 mm | 71.1 in.
Height 1365.001 mm | 53.7 in.
Wheelbase 2800.001 mm | 110.2 in.
Vehicles with similar dimensions
Suspension
Suspension Independent Double Wishbone with Anti roll bar, coil spring and adjustable shock absorbers
Steering
Rack and Pinion with Power Assist
Brakes
Front Brake Size 257.001 mm | 10.1 in.
Rear Brake Size 257.001 mm | 10.1 in.
Tires / Wheels
Tires 225/45 R17 91W
Wheels 17 inch x 7 inch 2 piece magnesium alloy rims c/w polished stainless steel edge rim, desgined by BBS
