Mercedes-Benz today revealed the 2008 CLK63 AMG Black Series — a street legal version of the Official F1 Safety Car. The Black Series is a 500 horsepower version of the AMG 6.3-liter V8 engine, with 0-60 mph acceleration of 4.1 seconds and an electronically limited top speed of 186 mph. It uses a seven-speed automatic with manual control, and features just two carbon fibre bucket seats instead of the usual 2+2 configuration.
The new Black Series model can be easily identified by its carbon-fiber flared fenders that are filled with larger, staggered-width wheels and tires. New AMG forged aluminum wheels (9 x 19 front, 9.5 x 19 rear) are shod with Pirelli P Zero Corsa sports tires (265 / 30 R 19 front, 285 / 30 R 19 rear). Larger vented and perforated composite disc brakes can be seen through the AMG wheels; front discs are 14.2 inches in diameter, with 13.0-inch discs at the rear.
Also obvious from the outside is a new front apron with carbon cooling air intakes under the front bumper and lateral air outlets in the front fenders, which feeds extra air to a larger radiator and a second transmission oil cooler. Redesigned side skirts under the doors lead to its flared rear fenders and a new rear apron with carbon-fiber air diffuser fins.
High-performance parts from the F1 Safety Car include an AMG sports exhaust, a limited-slip rear differential and a separate oil cooler for the rear final drive, which uses a thermostatically controlled cooling fan to limit temperature peaks. On the trunk lid, a carbon-fiber spoiler airflow helps reduce aerodynamic lift forces at high speed.
The chassis of the CLK63 AMG Black Series features adjustable suspension with new spring links, wheel carriers, thrust arms and camber and torque struts. For driving on the track, technicians can adjust the car’s ride height and also the compression and rebound characteristics of the shock dampers, as well as camber and toe-in. An extra measure of chassis stiffness during hard cornering is provided by strut braces in the engine compartment and trunk. Additionally, its ASR traction control and ESP stability control systems are specially calibrated for the demands of more intense track driving.
MOD EDIT : REPOST
https://www.pakwheels.com/forumreply_az_TopicID!43239~ForumID!1~pw.html
