Results 1 to 5 of 5
Like Tree7Likes
  • 4 Post By sars333
  • 2 Post By epigenius
  • 1 Post By hash4u
Thread: Tyre shop frauds
    sars333's Avatar
    Dec 2005
    795
    Default Tyre shop frauds
    Hello guys
    Like every one in Pakistan guys at tyre repair shops have also developed few scams.i thought of sharing it and purpose is to mention it to them so this robbery or fraud can be stopped.
    1) when u go for puncture check or to refill tyre air pressure .guy will put pressure or twist tyre nozzel in such a way that that it leaks. Or while on his way to submerge the tyre in water he will drive screw driver in it so when he submerges in water tons of bubbles cud be seen......you will wonder if such leak was there how come tyre was not flat in 5 mins........
    They will sell the tyre nozzle for 150 rupees..this nozzle is available for less than 50 rupees from market..always keep spare in car....they highly dislike it when u tell them u have spare nozel.
    2 )While checking for air pressure specially before motor way or any highway journey they will declare one tyre as having low pressure specially if u r sitting in car while he is checking pressure ..or even if u r there he will remove nozel in seconds and show u less pressure ...after that he will encircle tyre with chalk before submerging tyre in water showing u nails which r not leaking at time .he will take a bigger needle or screw driver and pretend to be removing the nail while actually inducing much larger puncture ....so plz donot remove small nail or screws which are not leaking and r seal......other wise u will end up with having 6 to 7 punctures.
    3)Check the tyre air pressure after he fixes tyre after repair.....because after repairing the over inflate tire sometimes tire pressure was more than 40.....
    Please stop them from these frauds reason is that although amount of money may be less 400 or 500 rupees which they make from this all ..but the destroy tyre worth 8-9 thousand.
    your experiences are welcomed
    Similar Threads:
    wakman2003's Avatar
    May 2006
    42
    912
    lanat ho in kamoon per thanx for sharing
    drive safe!
    epigenius's Avatar
    Apr 2012
    1,085
    33 Post(s)
    one more thing they all steal the tyre valve stem caps,check your car it must be missing a few
    hash4u's Avatar
    May 2005
    38
    24,378
    18
    406 Post(s)
    13 Thread(s)
    13
    besides the points mentioned
    most of these guys do not do the american puncture right
    couple of times these fixed punctures leaked
    i avoid external fix unless in a hurry or if they have the usual excuse "bijli nahi hai"
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by hash4u View Post
    I have visited some shops who kept some wood burning and would use that to heat up the irons to repair punctures - just in case "bijli nahi hai" - business didnt stop.
    for the needle and thread puncture, you can you diy it too - buy a set
